TrevorX
- Mar 10, 2015
I'm currently running the latest stable version of FreeNAS 11 (11.0-U4 (54848d13b)) and upgrading from 9.10 went fine - I've had no issues, which has been great. But I've noticed my Plex plugin is running a bit behind the current version, so I was thinking of reinstalling it from the command line and keeping it updated using a cron job.
And then I read a comment elsewhere that, actually, Plex runs a lot better from Linux than FreeBSD. So now I'm wondering if I should change the way I'm running it altogether. As well as my NAS, I also have a Hyper-V server that runs my PDC VM, RDP gateway and a bunch of test and development VMs that I only spin up when required, so it basically sits there 99% idle most of the time. Linux VMs now run perfectly well in Hyper-V 2016 (I've deployed quite a few for various roles now, they've all be rock stable), so running a Linux VM for Plex shouldn't be an issue. But it will be decoupled from the storage this way, which (without having read anything about it) I don't see any issues with, but I may be missing something here.
Additionally, if I either change the setup of Plex to be installed from the Jail instead of using the plugin, or install it to a VM on another server, do I need to transfer configuration files anywhere, or does it store the configuration within my Plex account, and it will be configured just by logging in?
I do realise that it is entirely likely that I could figure out the answer to my questions after spending a few hours reading through the forums, but I've done a few searches and couldn't easily see if converting the way Plex was running on FreeNAS required transfer of configuration files so I thought by asking a stupid question, at least it would help anyone else with similar questions.
Thanks!
Thanks!
