I had plex running and ended up having to move all of the data to new HDDs to upgrade them. I had some trouble installing plex, so I tried a fresh install on a new USB and I am still getting an error. I failed to copy what the original error was, but my current error is below. Any idea on what to do? I have a X8SIL-f mobo with 8gb of RAM (another 8 should be here next friday) and a X3450 processor.
Software Version: FreeNAS-11.0-U4 (54848d13b)
Request Method: POST
Request URL: https://192.168.1.241/plugins/plugi...e9e11c312e65a337e33b49d40470d2260842a1e7db53/
Traceback:
File "./freenasUI/jails/utils.py" in new_default_plugin_jail
718. w.create(**create_args)
File "./freenasUI/common/warden.py" in create
1097. return self.__call(warden_create(flags, **kwargs))
File "./freenasUI/common/warden.py" in __call
1070. tmp = obj.run()
File "./freenasUI/common/warden.py" in run
465. raise warden_exception(msg)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner
39. response = get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response
249. response = self._get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response
178. response = middleware_method(request, callback, callback_args, callback_kwargs)
File "./freenasUI/freeadmin/middleware.py" in process_view
162. return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
23. return view_func(request, *args, **kwargs)
File "./freenasUI/plugins/views.py" in install_available
306. raise e
302. jail = new_default_plugin_jail(plugin.unixname)
721. raise MiddlewareError(_("Failed to install plugin: %s") % e)
Exception Type: MiddlewareError at /plugins/plugin/install/4f0560ae632a97e9c4fee9e11c312e65a337e33b49d40470d2260842a1e7db53/
Exception Value: [MiddlewareError: b"Failed to install plugin: [warden_exception: cannot open 'FreeNAS/jails_2/.warden-template-pluginjail@clean': dataset does not exist\nERROR: Failed creating clean ZFS base clone\n]"]
Traceback:
306. raise e
