Plugin install problem
NightKing
Hello. i have FreeNAS-11.0-U1 and i cant install plugin.
Environment: Software Version: FreeNAS-11.0-U1 (aa82cc58d) Request Method: POST Request URL: http://192.168.1.200/plugins/plugin/upload/?X-Progress-ID=d575b882-2418-4abe-8f32-7c790a8b7979 Traceback: File "./freenasUI/jails/utils.py" in new_default_plugin_jail 675. w.template(**template_create_args) File "./freenasUI/common/warden.py" in template 1155. return self.__call(warden_template(flags, **kwargs)) File "./freenasUI/common/warden.py" in __call 1066. tmp = obj.run() File "./freenasUI/common/warden.py" in run 461. raise warden_exception(msg) File "./freenasUI/plugins/forms.py" in done 141. jail = new_default_plugin_jail("customplugin") File "./freenasUI/jails/utils.py" in new_default_plugin_jail 680. raise MiddlewareError(e) File "./freenasUI/middleware/exceptions.py" in __init__ 36. log.warn(str(self)) File "./freenasUI/middleware/exceptions.py" in __str__ 39. return "[%s: %s]" % (type(self).__name__, self.value.encode('utf-8')) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner 39. response = get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response 249. response = self._get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response 178. response = middleware_method(request, callback, callback_args, callback_kwargs) File "./freenasUI/freeadmin/middleware.py" in process_view 162. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 23. return view_func(request, *args, **kwargs) File "./freenasUI/plugins/views.py" in upload_nojail 497. return upload(request) File "./freenasUI/plugins/views.py" in upload 472. form.done() File "./freenasUI/plugins/forms.py" in done 145. raise MiddlewareError(str(e)) Exception Type: MiddlewareError at /plugins/plugin/upload/ Exception Value: [MiddlewareError: b"'warden_exception' object has no attribute 'encode'"]
Jailer
Not strong, but bad
And please post terminal output in code tags, that wall of text you posted is nearly impossible to read.
