Hi Guy's
Appologies if this has been addressed recently, but a search has not been fruitful.
I updated my NAS from TrueNAS Core to Scale blufin 22.12 today. I was aware that the Jails in Core would not carry across and was happy for this. This is a repository for data and acts as my media streamer using Plex.
I have gone to install Plex as an App using the Core Applications and have been getting around 40% and it hangs
When I check the shell i get the following error: unable to upgrade connection: contrainer not found ("plex")
My system is a repurposed gaming machine
intel i7-11700K
GPU EVGA 3080TI
Harddrives
4x 8TB across 2 pools
2x 4TB across 1 pool
MSI z490 MB
64GB DDR
It should be noted that I have been able to instrall the app without establing where the data set is, but when I go to connect it to the file, above error occurs. Is there a way to connect the data set without going via the APP function
intel i7-11700K
GPU EVGA 3080TI
Harddrives
MSI z490 MB
64GB DDR
