Is Plex still supported or works with TrueNAS 13.0 U2? As my original Plex plug-in seem to not work after when I upgraded from 12 to 13. So I decided to remove the Plex Plug-in and install a fresh copy. Uninstall went fine without any issue I can see. But now when I try to add it back in, using a custom setting, but only the following
1. Uncheck DHCP,
2. Uncheck NAT
3. Select vnet0 as the interface type
4. give it an IP
5. and subnet mask of 24 (hostname and IP are already in my DNS)
I keep getting the following error as soon as the installation begins
Error: HTTPConnectionPool(host='download.freebsd.org', port=80): Max retries exceeded with url: /ftp/releases/amd64 (Caused by NewConnectionError('< urllib3.connection.HTTPConnection object at 0x822d8dfa0 >: Failed to establish a new connection: [Errno 8] Name does not resolve'))
Any feedback or comment would be appreciated
1. Uncheck DHCP,
2. Uncheck NAT
4. give it an IP
