I've been having an issue with Plex, specifically related to codecs. When a file needs to be transcoded, Plex will occasionally need to download a new codec. Here's the error I receive in Plex:
Error in Plex Logs:
The issue is the codec folder/file is created with a .tmp file type. If I manually rename the folder and remove the .tmp the video transcodes as expected.
I cannot figure out why ".tmp" is being added. I assume this is a permissions issue, but don't know how to resolve it. As you can see from the screenshot above, I use a separate directory to store plugin config data. Which means this directory is not within the Plex Jail.
Has anyone else experienced this issue or know how to resolve it? I've tried deleting all of the files in the Codecs folder and allowing Plex to rebuild, but the issue persists.
			Error in Plex Logs:
