Hi guys,
Using 9.2.1.9
I've installed PlexMediaServer v0.9.11.1.678 using the automated installation through FreeNAS plugins.
Jail is configured, storage is shared, server is up, everything works AWESOME.
A few question though :
1) When in Configuration > Server > General
I keep getting an error message saying that the update didn't not work and that I should install the update manually.
Is that normal / wanted?
Should I install the update manually?
How ?
I don't want to mess up anything!
2) When in Configuration > Server > Connection
Every time I try to connect my server, it will not work.
Keeps saying that there was an error while trying to connect.
Those two problems above seem to be related to connectivity but everything else work fine!
I have a pfSense firewall with no proxy, no fancy setting, not anything configured except trafic shaping which, in the worst case scenario, would make it to process slower but never block it!
Also, downloading movie and TVshow info worst fantastic and fast!
Using 9.2.1.9
How ?
