And it gives me the same result as with the old FreeNAS installation.
Doesn't this mean it's NOT the USB stick? Because the message is exactly the same as yesterday.
The only difference is, is that I now don't have any volumes showing in the GUI, where I yesterday had the following (which was incorrect of course):
This showed up with the "old" installation of FreeNAS.
I also re-ran the commands which were given to me yesterday. Outputs are below
[root@freenas] ~# dmesg
Copyright (c) 1992-2012 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 8.3-RELEASE-p5 #2 r244158M: Wed Dec 12 10:04:42 PST 2012
root@build.ixsystems.com:/home/jpaetzel/8.3.0/os-base/amd64/usr/home/jpaetzel/8.3.0/FreeBSD/src/sys/FREENAS.amd64 amd64
Timecounter "i8254" frequency 1193182 Hz quality 0
CPU: AMD Phenom(tm) II X4 955 Processor (3214.05-MHz K8-class CPU)
Origin = "AuthenticAMD" Id = 0x100f43 Family = 10 Model = 4 Stepping = 3
Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
Features2=0x802009<SSE3,MON,CX16,POPCNT>
AMD Features=0xee500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM,3DNow!+,3DNow!>
AMD Features2=0x37ff<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS,SKINIT,WDT>
TSC: P-state invariant
real memory = 17179869184 (16384 MB)
avail memory = 16403611648 (15643 MB)
ACPI APIC Table: <GBT GBTUACPI>
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s)
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 1
cpu2 (AP): APIC ID: 2
cpu3 (AP): APIC ID: 3
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ioapic0: Changing APIC ID to 8
ioapic0 <Version 2.1> irqs 0-23 on motherboard
kbd1 at kbdmux0
hpt27xx: RocketRAID 27xx controller driver v1.0 (Dec 12 2012 10:04:31)
cryptosoft0: <software crypto> on motherboard
aesni0: No AESNI support.
acpi0: <GBT GBTUACPI> on motherboard
acpi0: [ITHREAD]
acpi0: Power Button (fixed)
acpi0: reservation of 0, a0000 (3) failed
acpi0: reservation of 100000, d7cf0000 (3) failed
Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
acpi_timer0: <32-bit timer at 3.579545MHz> port 0x4008-0x400b on acpi0
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
acpi_button0: <Power Button> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
vgapci0: <VGA-compatible display> port 0xde00-0xdeff mem 0xd8000000-0xdfffffff,0xfdbe0000-0xfdbeffff,0xfda00000-0xfdafffff irq 18 at device 5.0 on pci1
pci1: <multimedia, HDA> at device 5.1 (no driver attached)
pcib2: <ACPI PCI-PCI bridge> irq 18 at device 2.0 on pci0
pci2: <ACPI PCI bus> on pcib2
pcib3: <PCI-PCI bridge> at device 0.0 on pci2
pci3: <PCI bus> on pcib3
pcib4: <PCI-PCI bridge> at device 2.0 on pci3
pci4: <PCI bus> on pcib4
em0: <Intel(R) PRO/1000 Network Connection 7.3.2> port 0xcf00-0xcf1f mem 0xfd5e0000-0xfd5fffff,0xfd5c0000-0xfd5dffff irq 17 at device 0.0 on pci4
em0: Using an MSI interrupt
em0: [FILTER]
em0: Ethernet address: 00:1b:21:40:a0:4d
em1: <Intel(R) PRO/1000 Network Connection 7.3.2> port 0xce00-0xce1f mem 0xfd5a0000-0xfd5bffff,0xfd580000-0xfd59ffff irq 16 at device 0.1 on pci4
em1: Using an MSI interrupt
em1: [FILTER]
em1: Ethernet address: 00:1b:21:40:a0:4c
pcib5: <PCI-PCI bridge> at device 4.0 on pci3
pci5: <PCI bus> on pcib5
em2: <Intel(R) PRO/1000 Network Connection 7.3.2> port 0xbf00-0xbf1f mem 0xfd4e0000-0xfd4fffff,0xfd4c0000-0xfd4dffff irq 19 at device 0.0 on pci5
em2: Using an MSI interrupt
em2: [FILTER]
em2: Ethernet address: 00:1b:21:40:a0:4f
em3: <Intel(R) PRO/1000 Network Connection 7.3.2> port 0xbe00-0xbe1f mem 0xfd4a0000-0xfd4bffff,0xfd480000-0xfd49ffff irq 18 at device 0.1 on pci5
em3: Using an MSI interrupt
em3: [FILTER]
em3: Ethernet address: 00:1b:21:40:a0:4e
pcib6: <ACPI PCI-PCI bridge> irq 17 at device 9.0 on pci0
pci6: <ACPI PCI bus> on pcib6
pci6: <serial bus, USB> at device 0.0 (no driver attached)
ahci0: <ATI IXP700 AHCI SATA controller> port 0xff00-0xff07,0xfe00-0xfe03,0xfd00-0xfd07,0xfc00-0xfc03,0xfb00-0xfb0f mem 0xfe02f000-0xfe02f3ff irq 19 at device 17.0 on pci0
ahci0: [ITHREAD]
ahci0: AHCI v1.20 with 6 6Gbps ports, Port Multiplier supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich0: [ITHREAD]
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich1: [ITHREAD]
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich2: [ITHREAD]
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich3: [ITHREAD]
ahcich4: <AHCI channel> at channel 4 on ahci0
ahcich4: [ITHREAD]
ahcich5: <AHCI channel> at channel 5 on ahci0
ahcich5: [ITHREAD]
ohci0: <OHCI (generic) USB controller> mem 0xfe02e000-0xfe02efff irq 18 at device 18.0 on pci0
ohci0: [ITHREAD]
usbus0: <OHCI (generic) USB controller> on ohci0
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xfe02d000-0xfe02d0ff irq 17 at device 18.2 on pci0
ehci0: [ITHREAD]
usbus1: EHCI version 1.0
usbus1: <EHCI (generic) USB 2.0 controller> on ehci0
ohci1: <OHCI (generic) USB controller> mem 0xfe02c000-0xfe02cfff irq 18 at device 19.0 on pci0
ohci1: [ITHREAD]
usbus2: <OHCI (generic) USB controller> on ohci1
ehci1: <EHCI (generic) USB 2.0 controller> mem 0xfe02b000-0xfe02b0ff irq 17 at device 19.2 on pci0
ehci1: [ITHREAD]
usbus3: EHCI version 1.0
usbus3: <EHCI (generic) USB 2.0 controller> on ehci1
pci0: <serial bus, SMBus> at device 20.0 (no driver attached)
isab0: <PCI-ISA bridge> at device 20.3 on pci0
isa0: <ISA bus> on isab0
pcib7: <ACPI PCI-PCI bridge> at device 20.4 on pci0
pci7: <ACPI PCI bus> on pcib7
em4: <Intel(R) PRO/1000 Legacy Network Connection 1.0.4> port 0xaf00-0xaf3f mem 0xfddc0000-0xfdddffff,0xfdda0000-0xfddbffff irq 20 at device 6.0 on pci7
em4: [FILTER]
em4: Ethernet address: 00:0e:0c:65:fc:7c
ohci2: <OHCI (generic) USB controller> mem 0xfe02a000-0xfe02afff irq 18 at device 20.5 on pci0
ohci2: [ITHREAD]
usbus4: <OHCI (generic) USB controller> on ohci2
pcib8: <ACPI PCI-PCI bridge> at device 21.0 on pci0
pci8: <ACPI PCI bus> on pcib8
ahci1: <JMicron JMB363 AHCI SATA controller> mem 0xfd9fe000-0xfd9fffff irq 17 at device 0.0 on pci8
ahci1: [ITHREAD]
ahci1: AHCI v1.00 with 2 3Gbps ports, Port Multiplier supported
ahcich6: <AHCI channel> at channel 0 on ahci1
ahcich6: [ITHREAD]
ahcich7: <AHCI channel> at channel 1 on ahci1
ahcich7: [ITHREAD]
atapci0: <JMicron JMB363 UDMA133 controller> port 0x9f00-0x9f07,0x9e00-0x9e03,0x9d00-0x9d07,0x9c00-0x9c03,0x9b00-0x9b0f irq 17 at device 0.1 on pci8
atapci0: [ITHREAD]
ata2: <ATA channel> at channel 0 on atapci0
ata2: [ITHREAD]
pcib9: <ACPI PCI-PCI bridge> at device 21.1 on pci0
pci9: <ACPI PCI bus> on pcib9
ohci3: <OHCI (generic) USB controller> mem 0xfe029000-0xfe029fff irq 18 at device 22.0 on pci0
ohci3: [ITHREAD]
usbus5: <OHCI (generic) USB controller> on ohci3
ehci2: <EHCI (generic) USB 2.0 controller> mem 0xfe028000-0xfe0280ff irq 17 at device 22.2 on pci0
ehci2: [ITHREAD]
usbus6: EHCI version 1.0
usbus6: <EHCI (generic) USB 2.0 controller> on ehci2
amdtemp0: <AMD K8 Thermal Sensors> on hostb4
acpi_hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff irq 0,8 on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 900
atrtc0: <AT realtime clock> port 0x70-0x73 on acpi0
orm0: <ISA Option ROMs> at iomem 0xc0000-0xcefff,0xd5000-0xd5fff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
atkbd0: [ITHREAD]
ppc0: cannot reserve I/O port range
hwpstate0: <Cool`n'Quiet 2.0> on cpu0
fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Timecounters tick every 1.000 msec
hpt27xx: no controller detected.
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 480Mbps High Speed USB v2.0
usbus2: 12Mbps Full Speed USB v1.0
usbus3: 480Mbps High Speed USB v2.0
usbus4: 12Mbps Full Speed USB v1.0
usbus5: 12Mbps Full Speed USB v1.0
usbus6: 480Mbps High Speed USB v2.0
ugen0.1: <ATI> at usbus0
uhub0: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen1.1: <ATI> at usbus1
uhub1: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
ugen2.1: <ATI> at usbus2
uhub2: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
ugen3.1: <ATI> at usbus3
uhub3: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3
ugen4.1: <ATI> at usbus4
uhub4: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus4
ugen5.1: <ATI> at usbus5
uhub5: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus5
ugen6.1: <ATI> at usbus6
uhub6: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus6
uhub4: 2 ports with 2 removable, self powered
uhub5: 4 ports with 4 removable, self powered
uhub0: 5 ports with 5 removable, self powered
uhub2: 5 ports with 5 removable, self powered
uhub6: 4 ports with 4 removable, self powered
uhub1: 5 ports with 5 removable, self powered
uhub3: 5 ports with 5 removable, self powered
ugen5.2: <Logitech> at usbus5
ukbd0: <Logitech HID compliant keyboard, class 0/0, rev 1.10/1.80, addr 2> on usbus5
kbd2 at ukbd0
uhid0: <Logitech HID compliant keyboard, class 0/0, rev 1.10/1.80, addr 2> on usbus5
ugen2.2: <ASETEK> at usbus2
ugen1.2: <USBest Technology> at usbus1
umass0: <USBest Technology USB Mass Storage Device, class 0/0, rev 2.00/1.00, addr 2> on usbus1
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <WDC WD20EARX-00PASB0 51.0AB51> ATA-8 SATA 3.x device
ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
ada1: <WDC WD20EARX-00PASB0 51.0AB51> ATA-8 SATA 3.x device
ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada2 at ahcich2 bus 0 scbus2 target 0 lun 0
ada2: <WDC WD20EARX-008FB0 51.0AB51> ATA-8 SATA 3.x device
ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada3 at ahcich3 bus 0 scbus3 target 0 lun 0
ada3: <WDC WD20EARX-00PASB0 51.0AB51> ATA-8 SATA 3.x device
ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada3: Command Queueing enabled
ada3: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada4 at ahcich4 bus 0 scbus4 target 0 lun 0
ada4: <WDC WD20EARX-00PASB0 51.0AB51> ATA-8 SATA 3.x device
ada4: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada4: Command Queueing enabled
ada4: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada5 at ahcich5 bus 0 scbus5 target 0 lun 0
ada5: <WDC WD20EARX-00PASB0 51.0AB51> ATA-8 SATA 3.x device
ada5: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada5: Command Queueing enabled
ada5: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
da0 at umass-sim0 bus 0 scbus9 target 0 lun 0
da0: <OCZ RALLY2 0.00> Removable Direct Access SCSI-2 device
da0: 40.000MB/s transfers
da0: 3853MB (7892040 512 byte sectors: 255H 63S/T 491C)
SMP: AP CPU #3 Launched!
SMP: AP CPU #1 Launched!
SMP: AP CPU #2 Launched!
GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s).
Trying to mount root from ufs:/dev/ufs/FreeNASs1a
ZFS filesystem version 5
ZFS storage pool version 28
Probably not useful, but I want to mention everything so someone can provide a workable solution.
