Please Help Install...
pirateghost
Unintelligible Geek
@pirateghost Thank you. I have Windows 7 installed on a SSD drive. It is the only thing installed, I don't even have gpu drivers. Just a clean install. I will attach it to this server and do a firmware update. Is this the IT firmware I need? My MoBo is X8DTH-6F... (X8DTH-6F / X8DTH-iF -- IPMI_8DTH R 3.04 X8DTH_304.zip IPMI Firmware)
@Ericloewe Thank you, I will purchase one (an LSI SAS 9211 or 9207) down the road, if it is needed.
I don't know why you would buy a 9211 when you have one onboard. ;) the article I linked even said so. The link you provide there is for the IPMI firmware which has nothing to do with the SAS controller. The link I sent you has the links to the SAS firmware...
Please look at yourself from my shoes for a minute...
However, It seems people here are too eager to jump to conclusions and judge others. By judging I mean being snobby and well, this whole post is a great example of how rude most are.
I have no doubt you are directing it at me for asking you to search.
So sorry for my pitty me story, but I have a lot on my plate, a lot to learn as it is, and I was hopeful this place would be more supportive than RTFM and do a effing search. BTFW, I had to google what RTFM even meant! I don't know what the hell ISCIS or what the f* it is, or any of the other BS acronyms are! I have tried read the effing manual and I couldn't make heads or tails of it. Yes I am over my damn head, but I am trying to do something for my kids, so take a walk off a short plank!
Yep.. I asked you to search. Do you know why I asked you to search?
May I ask why you didn't ask me before judging me and deciding on my motives and reasons for asking you to search? Especially since you are calling me out for judging you when you clearly did the same thing by calling someone (most likely me) snobby and rude.
I asked you to search not because I'm snobby and wanted to give you an RTFM answer. I asked because you'd get more of an answer than I could provide on my cell phone trying to search the forums. There was no snobiness or anything involved. And I didn't judge, most certainly not as much as you.
There are so many Dell controllers out there I can't even keep track of what is and isn't "truly compatible" with FreeNAS. That's it. That's the ONLY reason I asked you to search. So despite me trying to help you, I feel I was judged, very quickly and very harshly I might add.
So please, before you judge me and try to tell me how I am acting, please ask yourself if you are judging, because from my perspective you absolutely are. Even to the point of being up front about what you've judged us as.
So please stop judging me (and anyone else that might be helping you) because I/we don't like being classified as judging someone when we're clearly being judged ourselves. We've got about 10 regulars and that's all. Burn those 10 bridges and you'll have zero help from anyone when you come back and have a serious problem that isn't so searchable in the forum. Yes, we're small enough that if just 5 people were you add you to their ignore list, you'll never get any kind of technical help again from the forum.
BamBamm
Again, I don't know what I am doing. I thought the 9211 would be a better option than on-board. I know add-on gpus are better than an on-board, so I was thinking it might be the same. Guess not, thank you for clarifying.
I was under the understanding that I could upgrade the firmware using Windows OS, then switch to FreeNAS... You said the link you provided was to update via FreeNAS...
You need to get the IT firmware from supermicro and follow their instructions to flash it.
You can use this method if you want to throw Windows on there if that would make you more comfortable for initial flash.
or you can just get the firmware and do it from freenas using the sasflash tool.
pirateghost
Unintelligible Geek
The link I provided told you how to do it on windows. It even gave links and told you what firmware files you needed.
If you have the firmware file, you can perform the flash from freenas. That's what I said. Please go back and read my link again.
BamBamm
@cyberjock
Not completely...
I "took a look from your shoes for a minute", now please look from my view point... Yes, I found your post rude, and after clarification I am without a doubt ashamed of myself, truly.
However, it wasn't just you. It was the other remarks that were made. Remarks about using a lower-case and upper-case lettering, and other comments. Alone it wasn't much, but when you put together all the "seemingly rude-intended" comments,
I honestly felt that... well I guess I felt you all were a bunch of educated nerds and frankly you didn't want to be bothered with someone not educated.
BamBamm
Sorry for wasting your time. I don't say that to be rude, I mean it honestly. I should have went and read the info. I thought it was for updating inside of FreeNAS and I was supposed to go to SuperMicro to update via Windows OS.
pirateghost
Unintelligible Geek
@ cyberjock
Not completely...
Technical subjects are a hard thing to tackle. There are many acronyms and slang that are necessary to understand. When dealing with technical people, expect to be corrected on the little things like that. It is true of any hobby or technical trade. Medical doctors will do the same thing. Not because they are trying to be know it all's or not be helpful, but because they are trying to make sure you understand the difference in these seemingly minor details. Details that, to the laymen, don't mean much.
Don't take offense to that, it is quite common.
BamBamm
That's it, but you need P20 for FreeNAS 9.3.1 (P16 for 9.3).
BamBamm
Firmware (87) i
Title
OS
Date
Type
Download
Create
+9211_8i_P7_Firmware_BIOS_UEFI_FCODE 04/06/2011 zip Download Create
+9211_8i_Package_For_P7_Firmware_BIOS_Upgrade_on_MSDOS_and_Windows 04/06/2011 zip Download Create
+9211_8i_Package_for_P8_Firmware_BIOS_Upgrade_on_MSDOS_and_Windows 04/06/2011 zip Download Create
+9211_8i_Package_for_P9_IR_IT_Firmware_BIOS_on_MSDOS_and_Windows 04/06/2011 zip Download Create
+9211_8i_Package_P10_IR_IT_Firmware_BIOS_for_MSDOS_Windows 06/15/2011 zip Download Create
+9211_8i_Package_P11_IR_IT_Firmware_BIOS_for_MSDOS_Windows 08/22/2011 zip Download Create
+9211_8i_Package_P12_IR_IT_Firmware_BIOS_for_MSDOS_Windows 11/15/2011 zip Download Create
+9211_8i_Package_P13_IR_IT_Firmware_BIOS_for_MSDOS_Windows 02/17/2012 zip Download Create
+9211_8i_Package_P13.5_IR_IT_Firmware_BIOS_for_MSDOS_Windows 10/02/2012 zip Download Create
+9211_8i_Package_P14_IR_IT_Firmware_BIOS_for_MSDOS_Windows 07/24/2012 zip Download Create
+9211_8i_Package_P15_IR_IT_Firmware_BIOS_for_MSDOS_Windows 11/07/2012 zip Download Create
+9211_8i_Package_P16_IR_IT_Firmware_BIOS_for_MSDOS_Windows 02/27/2013 zip Download Create
+9211_8i_Package_P20_IR_IT_Firmware_BIOS_for_MSDOS_Windows 09/22/2014 zip Download Create
+9211-8i_Package_P17_IR_IT_Firmware_BIOS_for_MSDOS_Windows 08/09/2013 zip Download Create
+9211-8i_Package_P18_IR_IT_Firmware_BIOS_for_MSDOS_Windows 12/04/2013 zip Download Create
+9211-8i_Package_P19_IR_IT_Firmware_BIOS_for_MSDOS_Windows 03/18/2014 zip Download Create
+EFI_Installer_P5 04/06/2011 zip Download Create
+Installer_P10_for_Linux Linux 05/13/2011 zip Download Create
+Installer_P10_for_MSDOS_and_Windows Windows 05/13/2011 zip Download Create
+Installer_P10_for_Solaris Solaris 05/13/2011 zip Download Create
+Installer_P10_for_VMware_ESX50 VMware ESX5.0 05/13/2011 zip Download Create
+Installer_P11_for_Linux Linux 08/22/2011 zip Download Create
+Installer_P11_for_MSDOS_and_Windows Windows 08/22/2011 zip Download Create
+Installer_P11_for_Solaris Solaris 08/22/2011 zip Download Create
+Installer_P11_for_VMware_ESX50 VMware ESX5.0 08/22/2011 zip Download Create
+Installer_P12_for_Linux Linux 11/08/2011 zip Download Create
+Installer_P12_for_MSDOS_and_Windows Windows 11/08/2011 zip Download Create
+Installer_P12_for_Solaris Solaris 11/08/2011 zip Download Create
+Installer_P12_for_VMware_ESX50 VMWware 11/08/2011 zip Download Create
+Installer_P13_for_Linux Linux 02/17/2012 zip Download Create
+Installer_P13_for_MSDOS_and_Windows Windows 02/17/2012 zip Download Create
+Installer_P13_for_Solaris Solaris 02/17/2012 zip Download Create
+Installer_P13_for_VMware_ESX50 VMware ESX5.0 02/17/2012 zip Download Create
+Installer_P14_for_FreeBSD FreeBSD 06/29/2012 zip Download Create
+Installer_P14_for_Linux Linux 07/24/2012 zip Download Create
+Installer_P14_for_MSDOS_and_Windows Windows 07/24/2012 zip Download Create
+Installer_P14_for_Solaris Solaris 07/24/2012 zip Download Create
+Installer_P14_for_Vmware_ESX50 VMware ESX5.0 07/24/2012 zip Download Create
+Installer_P15_for_FreeBSD FreeBSD 07/11/2012 zip Download Create
+Installer_P15_for_Linux Linux 11/06/2012 zip Download Create
+Installer_P15_for_MSDOS_and_Windows Windows 11/06/2012 zip Download Create
+Installer_P15_for_Solaris Solaris 11/06/2012 zip Download Create
+Installer_P15_for_UEFI UEFI 11/06/2012 zip Download Create
+Installer_P15_for_Vmware_ESX50 VMware ESX5.0 11/06/2012 zip Download Create
+Installer_P16_for_FreeBSD FreeBSD 03/01/2013 zip Download Create
+Installer_P16_for_Linux Linux 03/01/2013 zip Download Create
+Installer_P16_for_MSDOS_and_Windows Windows 03/01/2013 zip Download Create
+Installer_P16_for_Solaris Solaris 03/01/2013 zip Download Create
+Installer_P16_for_UEFI UEFI 03/01/2013 zip Download Create
+Installer_P16_for_Vmware_ESX50 VMware ESX5.0 03/01/2013 zip Download Create
+Installer_P17_for_FreeBSD FreeBSD 07/19/2013 zip Download Create
+Installer_P17_for_Linux Linux 07/19/2013 zip Download Create
+Installer_P17_for_MSDOS_and_Windows Windows 07/19/2013 zip Download Create
+Installer_P17_for_Solaris Solaris 07/19/2013 zip Download Create
+Installer_P17_for_UEFI UEFI 07/19/2013 zip Download Create
+Installer_P17_for_Vmware_ESX50 VMware ESX5.0 07/19/2013 zip Download Create
+Installer_P18_for_FreeBSD FreeBSD 12/04/2013 zip Download Create
+Installer_P18_for_Linux Linux 12/04/2013 zip Download Create
+Installer_P18_for_MSDOS_and_Windows Windows 12/04/2013 zip Download Create
+Installer_P18_for_Solaris Solaris 12/04/2013 zip Download Create
+Installer_P18_for_UEFI UEFI 12/04/2013 zip Download Create
+Installer_P18_for_Vmware_ESX50 VMware ESX5.0 12/04/2013 zip Download Create
+Installer_P19_for_FreeBSD FreeBSD 03/18/2013 zip Download Create
+Installer_P19_for_Linux Linux 03/18/2014 zip Download Create
+Installer_P19_for_MSDOS_and_Windows Windows 03/18/2014 zip Download Create
+Installer_P19_for_Solaris Solaris 03/18/2014 zip Download Create
+Installer_P19_for_UEFI UEFI 03/18/2014 zip Download Create
+Installer_P19_for_Vmware_ESX50 VMware ESX5.0 03/18/2014 zip Download Create
+Installer_P20_for_FreeBSD FreeBSD 09/18/2014 zip Download Create
+Installer_P20_for_Linux Linux 09/18/2014 zip Download Create
-Installer_P20_for_MSDOS_and_Windows
Windows Installer
Version: 20.00.00.00
File Size: 588 KB
Language: English
Read Me
Windows 09/18/2014 zip Download Create
+Installer_P20_for_Solaries Solaris 09/18/2014 zip Download Create
+Installer_P20_for_UEFI UEFI 09/18/2014 zip Download Create
+Installer_P20_for_Vmware_ESX50 VMware ESX5.0 09/18/2014 zip Download Create
+Installer_P8_for_Linux 04/06/2011 zip Download Create
+Installer_P8_for_MSDOS_and_Windows 04/06/2011 zip Download Create
+Installer_P8_for_Solaris 04/06/2011 zip Download Create
+Installer_P8_for_UEFI 04/06/2011 zip Download Create
+Installer_P9_for_Linux 04/06/2011 zip Download Create
+Installer_P9_for_MSDOS_and_Windows 04/06/2011 zip Download Create
+Installer_P9_for_Solaris 04/06/2011 zip Download Create
+Installer_P9_for_UEFI 04/06/2011 zip Download Create
+Linux_Installer_P5 04/06/2011 zip Download Create
+SAS9211-8i_P4 04/06/2011 zip Download Create
+SAS9211-8i_P5 04/06/2011 zip Download Create
+Solaris_Installer_P5 04/06/2011 zip Download Create
+Windows_Installer_P5 04/06/2011 zip Download
BamBamm
Should I do the: +9211-8i_Package_P19_IR_IT_Firmware_BIOS_for_MSDOS_Windows 03/18/2014 zip
Then run the: Installer_P20_for_MSDOS_and_Windows
Installer for MSDOS and Windows
LSI Corporation SAS2FLASH Release
Contents-
Installer for DOS(SAS2FLSH) : \sas2flash_dos_rel\sas2flsh Version no:20.00.00.00 Release date:18-SEP-14
Installer for x86(SAS2FLASH) : \sas2flash_win_x86_rel\sas2flash Version no:20.00.00.00 Release date:18-SEP-14
Installer for x64(SAS2FLASH) : \sas2flash_win_x64_rel\sas2flash Version no:20.00.00.00 Release date:18-SEP-14
Installer for ia64(SAS2FLASH) : \sas2flash_win_ia64_rel\sas2flash Version no:20.00.00.00 Release date:18-SEP-14
README_FOR_Installer_P20_MSDOS_and_Windows.txt
SAS2Flash_ReferenceGuide.pdf
SAS2FLASH_Phase20.0-20.00.00.00.pdf
Installation:
SAS2FLASH is stand-alone binary and can be executed from any location on a file system.For more details on installer please refer to the SAS2FLASH User manual included in this package.
BamBamm
BamBamm
What is a UEFI flasher? This comes with the sas2flash.exe mentioned in the other post...
The sas2flash.efi executable. It's available in some packages, instead of the DOS tool.
BamBamm
So I got it to work and it said I had no compatible devices....
BamBamm
SweetAndLow
Sweet'NASty
Find the recent thread about flashing p20 firmware and follow those directions.
