pkg install bash in a jail
Jacopx
Buonasera a tutti! :)
Is from 6 month that i can't create a Jail. Yesterday i have solved this problem but another one is comes out... If i try to install BASH i received:
root@matlab_1:/ # pkg install bash
Updating FreeBSD repository catalogue...
FreeBSD repository is up-to-date.
All repositories are up-to-date.
pkg: No packages available to install matching 'bash' have been found in the repositories
Of course something goes wrong... I have already try to update everything. I'm not sure that this repo file (/usr/local/etc/pkg/repos/FreeBSD.conf) is correct:
FreeBSD: {
  url: "pkg+http://pkg.FreeBSD.org/freebsd:10:x86:64/latest",
  mirror_type: "srv",
  enabled: yes
I really need to create jail, please help me!
Jacopx
tording99z28
I am actually having this same problem. It is trying to install a version of bash that the tax file does not exist. It is trying to install 4.3.18_2 and that file does not exist. bash-4.4.5 does exist on the freebsd url though. I did a pkg update and it says it updated but it still tries to install 4.3.18_2 instead of 4.4.5. Please help!!
Jacopx
I have solved the problem... This is the correct path of the configuration file:
FreeBSD: {
  url: "pkg+http://pkg.FreeBSD.org/freebsd:9:x86:64/latest",
  mirror_type: "srv",
  enabled: yes
I have changed from freebsd:10 --> freebsd:9
Jailer
Not strong, but bad
FreeBSD: {
  mirror_type: "srv",
  enabled: yes
Why in the world would you do that?
Jacopx
Because is the only way damnnn [emoji28]
I have change the jail template too, because the 9.10 template doesn't work. The 9.3 jailplugins is working but no with freebsd:10.
"Does it work?"
"Yes" --> DON'T TOUCH IT
