Hi all,
Today I had a moment and started to write my Piwigo plugin for TrueNAS based on Unofficial iocage Plugin manual
I have new file piwigo.json and post_install.sh, but before I can finish this, please may I ask you to take a look and check if I'm doing all in proper way?
1. piwigo.json
2. post_install.sh:
3. Is there any other way to modify/edit files I'm trying to replace in post_install.sh with "FETCH -O" ?
4. I'm having a problem with setting up mysql database, with user and password.
1. piwigo.json
    "name": "Piwigo",
    "plugin_schema": "2",
    "release": "11.3-RELEASE",
    "artifact": "https://github.com/AfroUSApl/piwigo.git",
    "official": false,
    "properties": {
        "vnet": 1,
        "dhcp": 1
    "pkgs": [
        "ImageMagick7-nox11",
        "git",
        "php73",
        "php73-exif",
        "php73-filter",
        "php73-gd",
        "php73-hash",
        "php73-mbstring",
        "php73-mysqli",
        "php73-json",
        "php73-session",
        "php73-zip",
        "php73-zlib",
        "nginx",
        "mariadb105-server"
    "packagesite": "http://pkg.FreeBSD.org/${ABI}/latest",
    "fingerprints": {
        "iocage-plugins": [
                "function": "sha256",
                "fingerprint": "b0170035af3acc5f3f3ae1859dc717101b4e6c1d0a794ad554928ca0cbb2f438"
    "revision": "0"
2. post_install.sh:
#!/bin/sh
# Enable the service
sysrc -f /etc/rc.conf nginx_enable="YES"
sysrc -f /etc/rc.conf mysql_enable="YES"
sysrc -f /etc/rc.conf php_fpm_enable="YES"
# Start the service
service nginx start 2>/dev/null
service php-fpm start 2>/dev/null
service mysql-server start 2>/dev/null
#Copy a base MySQL configuration to use
cp /usr/local/etc/mysql/my-small.cnf /usr/local/etc/mysql/my.cnf
# Configure the default PHP settings
cp /usr/local/etc/php.ini-production /usr/local/etc/php.ini
# Create user 'piwigo'
pw user add -n piwigo -s /sbin/nologin -c "Piwigo"
# Create a configuration directory to make managing individual server blocks easier
mkdir /usr/local/etc/nginx/conf.d
mkdir /usr/local/etc/php-fpm.d
#https://docs.nextcloud.com/server/13/admin_manual/installation/installation_wizard.html do not use the same name for user and db
USER="piwigouser"
DB="piwigodb"
# Save the config values
echo "$DB" > /root/dbname
echo "$USER" > /root/dbuser
export LC_ALL=C
cat /dev/urandom | tr -dc 'a-zA-Z0-9' | fold -w 16 | head -n 1 > /root/dbpassword
PASS=`cat /root/dbpassword`
if [ -e "/root/.mysql_secret" ] ; then
   # Mysql > 57 sets a default PW on root
   TMPPW=$(cat /root/.mysql_secret | grep -v "^#")
   echo "SQL Temp Password: $TMPPW"
# Configure mysql
mysql -u root -p"${TMPPW}" --connect-expired-password <<-EOF
ALTER USER 'root'@'localhost' IDENTIFIED BY '${PASS}';
CREATE USER '${USER}'@'localhost' IDENTIFIED BY '${PASS}';
GRANT ALL PRIVILEGES ON *.* TO '${USER}'@'localhost' WITH GRANT OPTION;
GRANT ALL PRIVILEGES ON ${DB}.* TO '${USER}'@'localhost';
FLUSH PRIVILEGES;
EOF
# Make the default log directory
mkdir /var/log/zm
chown www:www /var/log/zm
else
   # Mysql <= 56 does not
# Configure mysql
mysql -u root <<-EOF
UPDATE mysql.user SET Password=PASSWORD('${PASS}') WHERE User='root';
DELETE FROM mysql.user WHERE User='root' AND Host NOT IN ('localhost', '127.0.0.1', '::1');
DELETE FROM mysql.user WHERE User='';
DELETE FROM mysql.db WHERE Db='test' OR Db='test_%';
FLUSH PRIVILEGES;
EOF
fi
# Downloading modified main nginx config file
fetch -o /usr/local/etc/nginx/nginx.conf https://raw.githubusercontent.com/AfroUSApl/piwigo/master/nginx.conf
# Download modified php config file
fetch -o /usr/local/etc/php.ini https://raw.githubusercontent.com/AfroUSApl/piwigo/master/php.ini
# Download Piwigo version 11.x from GitHub
cd /usr/local/www
git clone -b 11.x https://github.com/Piwigo/Piwigo.git
mkdir /usr/local/www/Piwigo/_data
# Change the ownership of the piwigo directory
chown -R piwigo:www /usr/local/www/Piwigo
# Create an piwigo.example.com server block config file
fetch -o /usr/local/etc/nginx/conf.d/piwigo.example.com.conf https://raw.githubusercontent.com/AfroUSApl/piwigo/master/nginx/conf.d/piwigo.example.com.conf
# Create the piwigo php-fpm pool config file and WWW config file
fetch -o /usr/local/etc/php-fpm.d/piwigo.example.com.conf https://raw.githubusercontent.com/AfroUSApl/piwigo/master/php-fpm.d/piwigo.example.com.conf
fetch -o /usr/local/etc/php-fpm.d/www.conf https://raw.githubusercontent.com/AfroUSApl/piwigo/master/php-fpm.d/www.conf
#restart the services to make sure we have pick up the new permission
service php-fpm restart 2>/dev/null
#nginx restarts to fast while php is not fully started yet
sleep 5
service nginx restart 2>/dev/null
echo "Database Name: $DB" > /root/PLUGIN_INFO
echo "Database User: $USER" >> /root/PLUGIN_INFO
echo "Database Password: $PASS" >> /root/PLUGIN_INFO
