Pid 2 [g_event] 100% busy
maurertodd
I was reviewing the status of my FreeNAS server and noticed the load was around 1. Then I looked at the CPU utilization on the reporting tab and saw it was at bouncing around 100% of the 200% available. I looked at the system processes and saw nothing. So I logged in via SSH and did the used "ps aux" of which the first few lines are below. What is g_event and why might it be using 100% for days on end?
FreeNAS-8.3.0-RELEASE-p1-x64 (r12825)
Intel(R) Celeron(R) CPU G550 @ 2.60GHz
3955MB
[todd@freenas] /# ps aux
USER PID %CPU %MEM VSZ RSS TT STAT STARTED TIME COMMAND
root 11 104.7 0.0 0 32 ?? RL 27Mar13 72136:20.00 [idle]
root 2 100.0 0.0 0 16 ?? RL 27Mar13 10945:07.72 [g_event]
root 0 0.0 0.2 0 6832 ?? DLs 27Mar13 140:41.82 [kernel]
root 1 0.0 0.0 3204 388 ?? ILs 27Mar13 0:00.01 /sbin/init --
root 3 0.0 0.0 0 16 ?? DL 27Mar13 14:43.32 [g_up]
root 4 0.0 0.0 0 16 ?? DL 27Mar13 22:01.33 [g_down]
root 5 0.0 0.0 0 16 ?? DL 27Mar13 0:00.00 [crypto]
root 6 0.0 0.0 0 16 ?? DL 27Mar13 0:00.00 [crypto returns]
root 7 0.0 0.0 0 16 ?? DL 27Mar13 0:00.00 [xpt_thrd]
root 8 0.0 0.0 0 16 ?? DL 27Mar13 0:00.00 [g_mp_kt]
root 9 0.0 0.0 0 16 ?? DL 27Mar13 0:05.80 [pagedaemon]
r
titan_rw
I've seen that before.
On my system it was after it dropped a hard drive due to read problems.
Rebooting the system fixed it. Replacing the failing hard drive fixed the underlying problem.
titan_rw
In as much as I would call failing hardware a bug.
I replaced the drive, and haven't had the problem since.
joeschmuck
Old Man
If you suspect a drive, run a long smart test on all the drives and check the results. If you get nothing, do it again just to validate it.
Are you encrypting your drives?
I see the same issue. Not running with encrypted drives.
A drive started throwing read errors, and was booted out of the pool.
g_event started consuming 100% of the CPU.
I would think this is a bug--especially for a NAS. A drive failing shouldn't cause the CPU to max out and require a reboot.
