# zpool status pool: tank state: ONLINE scrub: scrub in progress for 1h37m, 0.01% done, 11873h0m to go config: NAME STATE READ WRITE CKSUM tank ONLINE 0 0 0 raidz2 ONLINE 0 0 0 ada0p2 ONLINE 0 0 0 ada1p2 ONLINE 0 0 0 ada2p2 ONLINE 0 0 0 ada3p2 ONLINE 0 0 0 ada4p2 ONLINE 0 0 0 ada5p2 ONLINE 0 0 0 9.19M repaired # iostat -x extended device statistics device r/s w/s kr/s kw/s wait svc_t %b da0 0.9 1.5 10.2 6.4 0 82.4 0 ada0 0.5 0.4 38.1 2.4 0 25.7 1 ada1 0.5 0.3 36.6 2.2 0 26.6 1 ada2 0.5 0.3 38.7 1.8 0 22.8 1 ada3 0.5 0.3 39.6 2.1 0 23.0 1 ada4 0.3 0.4 12.5 2.4 0 26.8 1 ada5 0.3 0.4 12.7 4.3 6 9780.7 99 md0 0.0 0.5 0.1 1.4 0 0.1 0 md1 0.0 0.0 0.1 0.0 0 0.0 0 md2 0.0 3.2 0.1 14.4 0 0.2 0 pass0 0.0 0.0 0.0 0.0 0 0.0 0 pass1 0.0 0.0 0.0 0.0 0 0.0 0 pass2 0.0 0.0 0.0 0.0 0 0.0 0 pass3 0.0 0.0 0.0 0.0 0 0.0 0 pass4 0.0 0.0 0.0 0.0 0 0.0 0 pass5 0.0 0.0 0.0 0.0 0 0.0 0 pass6 0.0 0.0 0.0 0.0 0 0.0 0 # vmstat procs memory page disks faults cpu r b w avm fre flt re pi po fr sr da0 ad0 in sy cs us sy id 0 0 0 786M 14G 231 0 0 1 259 0 0 0 34 928 787 1 0 99
Output from top:
last pid: 3854; load averages: 0.00, 0.01, 0.00 up 0+01:48:44 15:08:10 48 processes: 1 running, 47 sleeping CPU: 0.1% user, 0.0% nice, 0.2% system, 0.0% interrupt, 99.7% idle Mem: 133M Active, 37M Inact, 967M Wired, 468K Cache, 163M Buf, 14G Free Swap: 12G Total, 12G Free PID USERNAME THR PRI NICE SIZE RES STATE C TIME WCPU COMMAND 1816 root 1 44 0 6772K 1248K select 0 0:09 0.00% powerd 2184 root 7 44 0 66836K 9372K ucond 2 0:07 0.00% collectd 2062 root 6 45 0 166M 98420K uwait 1 0:05 0.00% python 2213 www 4 44 0 28272K 12016K nanslp 0 0:03 0.00% transmission-daemon 2605 www 1 44 0 19328K 4036K kqread 1 0:01 0.00% lighttpd 1808 root 1 44 0 11780K 2740K select 0 0:00 0.00% ntpd 1601 root 1 44 0 39208K 6404K select 0 0:00 0.00% nmbd 2674 root 1 44 0 67232K 25484K wait 0 0:00 0.00% python 2326 root 1 50 0 7832K 1500K nanslp 0 0:00 0.00% cron 1998 root 1 44 0 16088K 4540K select 2 0:00 0.00% proftpd 1482 root 1 44 0 46788K 9396K select 0 0:00 0.00% smbd 3564 mbernard 1 44 0 33304K 5104K select 1 0:00 0.00% sshd 3840 root 1 44 0 9224K 2372K CPU2 2 0:00 0.00% top 1262 root 1 44 0 6904K 1460K select 0 0:00 0.00% syslogd 3608 root 1 44 0 10172K 3012K pause 2 0:00 0.00% csh 3562 root 1 49 0 33304K 5068K sbwait 0 0:00 0.00% sshd 944 root 1 44 0 3204K 716K select 2 0:00 0.00% devd
And in IO mode:
3; load averages: 0.01, 0.02, 0.00 up 0+01:47:39 15:07:05 48 processes: 1 running, 47 sleeping CPU: 0.0% user, 0.0% nice, 0.0% system, 0.0% interrupt, 100% idle Mem: 133M Active, 37M Inact, 967M Wired, 468K Cache, 163M Buf, 14G Free Swap: 12G Total, 12G Free PID USERNAME VCSW IVCSW READ WRITE FAULT TOTAL PERCENT COMMAND 1816 root 18 0 0 0 0 0 0.00% powerd 2184 root 0 0 0 0 0 0 0.00% collectd 2062 root 2 0 0 0 0 0 0.00% python 2213 www 42 0 0 0 0 0 0.00% transmission-daemon 2605 www 2 0 0 0 0 0 0.00% lighttpd 1808 root 2 0 0 0 0 0 0.00% ntpd 1601 root 0 0 0 0 0 0 0.00% nmbd 2674 root 0 0 0 0 0 0 0.00% python 2326 root 0 0 0 0 0 0 0.00% cron 1998 root 0 0 0 0 0 0 0.00% proftpd 1482 root 0 0 0 0 0 0 0.00% smbd 3564 mbernard 1 0 0 0 0 0 0.00% sshd 1262 root 0 0 0 0 0 0 0.00% syslogd 3608 root 0 0 0 0 0 0 0.00% csh 3562 root 0 0 0 0 0 0 0.00% sshd 944 root 0 0 0 0 0 0 0.00% devd 3565 mbernard 0 0 0 0 0 0 0.00% bash
I'm fairly certain that a ZFS scrub should not take until October 2013 to complete. I'm a little concerned by the iostat output for ada5, but I don't know if its stats look like that because of the scrub, or if they're an indication of some problem with the drive (and hence why the scrub is taking forever).
For what it's worth, I definitely do not believe I am CPU bound, and I have 16 GB RAM that I don't think ever gets fully utilized. I think my disks are the weakest link in my system.
Any idea what might be wrong, or what I can do to get to the root of the issue?
