MendozaDOD
- Nov 1, 2020
Just thought I'd give everyone a heads up trying to setup a jail that uses the new OpenVPN V2.5 to connect to PIA's (Private Internet Access) VPN Servers.
With OpenVPN 2.5 they changed the default ciphers that it can use and the standard config files used in V2.4 and previous that use (AES-128-CBC+SHA1) no longer work. What I've found so far is only the Fourth Generation Strong Configuration Files work that use AES-256-CBC+SHA25. Not all of PIA's servers support these connections :(
The Fourth Gen config files can't be found on PIA's standard OpenVPN Config Files area. I was only able to find them here: https://www.privateinternetaccess.com/helpdesk/kb/articles/where-can-i-find-your-ovpn-files
And... Yes this all does work with 12.1-RELEASE-p10 jails :)
Hope this helps
Hope this helps
