- Jul 2, 2019
Hi Folks - I'm not sure what is going on. My FreeNAS box was running fine but a cuople of days ago I was adding a new share (SMB) - add the dataset in a pool, grant group rights to that dataset, create the actual SMB share - and things started going wrong.
The first sign was that my UniFi controller jail failed. I eventually determined that the permissions on the jail were wrong. I have a thread on that one that I marked as solved: UniFi Controller in Jail - UniFi stopped and will not start. As @dlavigne noted:
Tonight, I found that my Emby jail would not longer play any movies. The Emby libraries are actually different datasets (one for movies, TV shows and music) that have are SMB shares and are mounted to the Emby jail.
Two questions:
1. Does anyone have any idea what is going on? Was it something that I did? (I need to know so that I don't do it again!)
2. Is there any way to fix this on a global basis? (I fear the answer is "No!"...)
Typically mucking with perms in jails ends in unhappiness :-(
Two questions:
