Hi!
I'm running TrueNAS-SCALE-23.10.2 and made a pool for my data called "datapool".
I installed syncthing from TrueNAS charts and configured it with user and group 568 (apps). To be more flexible using my existing structure for backup fotos and files from my smartphone with syncthing, I set the host path directly to the pool (/mnt/datapool). Syncthing works perfectly but I recognized, that now the unix permissions for the whole root datset (/mnt/datapool) was changed to owner "apps" and group "apps" and syncthing added folders which I cannot access.
Is there a way to reset/change the unix permissions on the pool? The documentation for TrueNAS scale says, it's not possible using the ACL editor. Unfortunately I don't have any Linux skills for command line. Can u please help me?
Thx!
Thx!
