I am hoping for some guidance, I have been struggling for a few days reviewing available TrueNAS Scale+Syncthing information...
I am unable to have Syncthing sync files created by non 'apps' users.
I suspect something with permissions as I am not a linux guru but a novice.
Setup:
TrueNAS-SCALE-22.12.0
Syncthing v1.23.0
I have dataset /mnt/Pool1/SyncThing-Share used by Syncthing successfully.
Syncthing works and syncs files to another server only when the file owner/group is 'apps'
If I create a file in /mnt/Pool1/SyncThing-Share with another user, I receive error:
If I re-apply above ACL (which changes all files to owner = apps, group = apps) then all files will then successully sync via Syncthing...
This is not useful for me as files will be created in the /mnt/Pool1/SyncThing dataset by other users.
Thank you for any help.
Paul.
Setup:
Syncthing v1.23.0
- Configured Syncthing
- Configured /mnt/Pool1/Syncthing dataset permissions (this is where I suspect my issue is)
- User - apps
- Group - apps
Paul.
