Now we're getting somewhere! Lots of things you can do to troubleshoot here. Try the stat and summary tools, arc_summary.py and arcstat.py and see if you can find some coorelation.Hi Dave,
This is a really good point - the graphs are showing an L2ARC size of 8.4T!!! Attached are graphs but it looks like this might be where the issue is coming in? Top is now reporting 156GB Total ARC
Double check your disks and make sure you didn't accidently use the SSD + your vdev or one of the HGST drives as cache! I only say this because you say you're using 8TB drives and you got an 8.4TB cache! I really doubt it's because of compression artifacts. with a 240GB drive, you would have to be doing a 35x compression ratio on your video files to get to 8.4TB. If you truly have 8.4TB of L2ARC, then removing it should take care of it. 128GB of RAM and 8.4TB of L2ARC is a bad combination. Some memory is needed for mapping. I believe there's a post out there about the proper RAM/L2ARC size ratio.
Since it's an archive, perhaps you have the luxury of rebooting. My suggestion would be to remove (all) your L2ARC devices for now and see if the suttering goes away. At 10% cache hit and the overhead of needing to map your L2ARC space, you're probably better off without it.
Good luck!
