freebsdrules
- Oct 3, 2016
Hi all-
I have a new build I've just about completed for our home FreeNAS server. Hardware specs are below, as are intended uses. I've had a FreeNAS server in the past but wanted to get feedback on best possible storage/pool setups given my setup. Let me know what you would do.
Hardware
1. Supermicro 3U case which includes 16x 3.5" drive bays and backplane.
2. 16x 6TB Seagate 6TB Enterprise Hard Disk Drive - 7200 RPM SAS 12Gb/s 128MB 3.5" ST6000NM0034.
3. Supermicro X8DTH-i motherboard.
4. 2x LSI 9211-8I IT Mode SAS SATA 8-port PCI-E 6Gbps HBA Cards
5. 2x X5680 Xeons @ 3.33 GHz, 6 cores each, 12 cores total
6. 96GB ECC RAM
7. 10gbps fiber NIC (can't recall exact one off hand).
Uses
1. This is mostly used as a local/home storage server. I use it to store regular data (tax returns, financial spreadsheets, etc.) as well as photos, music, and movies for streaming.
2. I've recently added DVR data and tons of data from home security cameras.
3. Plex - it will run/host our internal plex server to both stream local media and stream live and dvr playback from 2 hdhomerun boxes fed from an over air antenna.
Setup
I am thinking I'll use raidz3 and was initially thinking one big pool. Thoughts? At least half the space will be reserved for security camera footage.
Hardware
6. 96GB ECC RAM
Uses
Setup
