I have done some folder browsing test and also some huge file copy.
The hardware used for the test is as below.
WIN 2008 r2
Intel Xeon E5507 2.27 GHz
8 GB memory
Hardware Raid1 SCSI disk 10k rpm
FreeNAS Mini (Asrock C2750D4I)
32GB memory
Raid 10 (4* 4TB WD Red)
FreeNAS Backup
8 GB memory
Raid1 (2* 9 TB WD red)
Athlon AMD 64 4200+ 2.2 GHz
Proxmox 3.2
7GB memory (only 1024 MB is designated for the container)
Single old spinning disk
Athlon AMD 64 4200+ 2.2 GHz (same old hardware as FreeNAS Backup but with slower disk)
Client : HP Z600 workstation
12 GB memory
SSD 120GB
Win 7
FreeNAS versions :
9.3
9.10.1-U2
Proxmox 3.2
Using here a openvz container for my test. Witch in it's turn adds a bit overhead. The Linux kernel should be based on RHEL7x
Samba version 3.6.6
File system is ext3
Scripts.
For making 50k+ files
Folder browsing script (obs windows bat file)
Iperf
First I measured the network with iperf. Iperf version 2.09 is used on the windows client and WIN2008. Iperf 2.0.5 is used on the *nix boxes.
For server side :
For client side :
All three servers (FreeNAS mini, FreeNAS backup, WIN 2008) clocked in at 860 MBits/sec. The Openvz container on the Proxmox box was this day a fraction slower 800 MBits/sec. This box sits next to its brother FreeNAS backup box.
Preparation :
On each box 2 folders is generated.
Folder 1 50k files is added.
Folder 2 will hold a huge file 10.5 Gb for copy testing.
Each folder listening is done with the same bat file. For BSD boxes cpu core is monitored with top -P
Win 2008 r2
1,1 sec folder browsing script
58 MB/sec copy huge file from server
94 MB/sec copy to server
FreeNAS mini 9.10
17,8 sec folder browsing script (87% utilization on single core)
18 – 30 sec while jumping in and out with windows file explorer.
FreeNAS backup 9.10
28.20 sec for folder browsing script (75% utilization on single core)
28 sec more or less steady while jumping in and out with windows file explorer.
proxmox 3.2
1,9 sec folder browsing script
85 MB/sec copy huge file from server
55 MB/sec copy huge file to server
After adding auxiliary parameter on shares ...
FreeNAS mini 9.10
17.3 sec folder browsing script
89 MB/sec copy huge file from server
98 MB/sec copy huge file to server
FreeNAS backup 9.10
27.9 sec folder browsing script
95 MB/sec copy huge from server
98 MB/sec copy huge to server
Not much of a change ...
Booted up the FreeNAS mini into 9.3
FreeNAS mini 9.3
3.6 sec for folder browsing script
110 MB/sec for copy huge file from server
85 MB/sec for copy huge file to server
Summary :
9.3 outperform 9.10 when it comes to folder browsing. But windows will even be around 3 times faster then 9.3. Proxmox (based on debian) will be between 9.3 and win2008.
Yes the test is done over different hardware, but the win2008 box i several years old. And still it doing better on this topic then the samba shares.
If we sort them from fast to slow.
win2008 (ntfs) 1,1 sec
Proxmox 3.2 (ext3) 1,9 sec
FreeNAS 9,3 (zfs) 3,6 sec
FreeNAS 9.10 (zfs) 17,3 sec
What is your measurements from my scripts ?
For easy mimic my result make this folder structure.
In measure.bat paste the folder browse script code above.
From your win client map the share to some letter and just hit the bat file. If you want to have the bat file locally just change the line
One ting is odd thought. When running my browsing script on Proxmox 3.2 it miss its first pass. Se example output bellow.
This is not the case with FreeNAS ZFS. Se bellow
WIN 2008 r2
8 GB memory
32GB memory
FreeNAS Backup
8 GB memory
Proxmox 3.2
12 GB memory
SSD 120GB
Win 7
FreeNAS versions :
9.3
9.10.1-U2
Proxmox 3.2
Samba version 3.6.6
File system is ext3
Scripts.
#!/bin/bash
for n in {1..50000}
do
touch $n;
done
@echo off
REM http://stackoverflow.com/questions/9922498/calculate-time-difference-in-windows-batch-file
cls
CALL :GetStartTime
rem Any process here...
CALL :GetStartTime
CALL :GetEndTime
for /l %%i in (1, 1, 3) do (
set /A newstart=end
CALL :GetEndTime
dir manyfiles >NUL
set /A elapsed=end-newstart
echo For run %%i
CALL :ShowTime
set cnt=%%i
echo .............
echo .............
echo for %cnt% iterations:
echo total time :
set /A elapsed=end-start
CALL :ShowTime
echo .............
echo average time :
set /A elapsed=(end-start)/cnt
CALL :ShowTime
:: End main program
GOTO End
REM *** Get end time:
:GetEndTime
for /F "tokens=1-4 delims=:.," %%a in ("%time%") do (
set /A "end=(((%%a*60)+1%%b %% 100)*60+1%%c %% 100)*100+1%%d %% 100"
GOTO :EOF
REM *** Get start Time ***
:GetStartTime
rem Get start time:
set /A "start=(((%%a*60)+1%%b %% 100)*60+1%%c %% 100)*100+1%%d %% 100"
GOTO :EOF
REM *** Show elapsed time: ***
:ShowTime
set /A hh=elapsed/(60*60*100), rest=elapsed%%(60*60*100), mm=rest/(60*100), rest%%=60*100, ss=rest/100, cc=rest%%100
if %mm% lss 10 set mm=0%mm%
if %ss% lss 10 set ss=0%ss%
if %cc% lss 10 set cc=0%cc%
::echo %hh%:%mm%:%ss%,%cc%
echo %ss%,%cc%
GOTO :EOF
:End
pause
Iperf
For server side :
iperf -s
For client side :
iperf -c 192.168.100.2 .. and so on
Preparation :
Win 2008 r2
FreeNAS mini 9.10
FreeNAS backup 9.10
proxmox 3.2
store dos attributes = no ea support = no map archive = no map hidden = no map system = no map readonly = no case sensitive = true default case = lower preserve case = no short preserve case = no
FreeNAS mini 9.10
FreeNAS backup 9.10
FreeNAS mini 9.3
Summary :
- |--manyfiles -| (add 50k+ files in this folder) |-measure.bat
dir manyfiles >NUL to suite your needs.One ting is odd thought. When running my browsing script on Proxmox 3.2 it miss its first pass. Se example output bellow.
For run 1 00,01 For run 2 02,01 For run 3 02,01 ............. ............. for 3 iterations: total time : 04,03 ............. average time : 01,34 Press any key to continue . . .
For run 1 03,44 For run 2 03,50 For run 3 03,50 ............. ............. for 3 iterations: total time : 10,45 ............. average time : 03,48 Press any key to continue . . .
