Hi Group!
Thanks for having me in the group and talking the time to talk to me. A little about me quick.
I started with FreeNas back when it was 8.00 something I think. I put that system together back in 08-09ish used it as a gaming computer for a short time and then switched it over to a Freenas box. It was running a AMD Phenom II X4 940, 16gigs of ram and 6 drives. This system worked great as a File storage system and a Plex box. The only issue I ever had was drives dying every couple of years and I would just wipe it and start over with new drives. It used a flash drive as a boot device that I loved because it opened up one more Sata port for a drive. I shut down this system a little over a year ago and its time to rebuild from the ground up. Its been so long since I put this system together I have to start over myself. I did very little for management with the Freenas box due to it just working so I know little about Truenas itself. I do a lot within the PC world of hardware mainly AMD stuff. I build a lot of gaming computers and for fun I XOC systems with LN2. I always have extra parts laying around because of this. I have spent a good amount of time rereading all the guilds and searching the forums trying to build the best system I can with some of the parts I already had laying around here and purchasing the best possible parts for my use case. I am hoping to get 10 plus years again out of this build if possible. My use case has grown a little for this build since the last build. I want to be able to store files again pictures and raw video plus run Plex again. I want to be able to transcode two streams of Plex from 4K to what ever the device needs with subs outside my local network at the same time. Thats why I used this CPU instead of a smaller one. I have a 10GBe network now so I can move large files to the Nas a little better then before with just a 1GBe network. My goal is to max out the 10GBe network from my shop PC to the Nas box. I have Cat 8 cabling and 10GBe switches with Intel X540-T2s for both ends.
My build so far is.
AMD 5950X
Asrack X570D4U mother board PCI 4.0
128 gigs 3200 ECC ram from Nemix (never heard of them any input would be great)
Intel X540-T2 10GBe Nic card
Samsung 850 EVO 120gig SSD sata Boot drive
Qty 5 Samsung EVO 2TB Sata SSDs (more on this later)
PCIe HBA SAS 3008 9003-8I???? (more on this later)
Would my use case benefit from adding a NVME drive for a SLOG or any other type of Cache? I know some benefits can be had from this when running a huge Plex library. This Plex will Be servicing about 6 connections of different types. I also want to send large files to the Nas as fast as possible I think the benefits come from use of spinner drives whereas I am using all SSDs and a larger ram pool do I need this? I have a bunch of 1 and 2 TB NVME drives sitting here doing nothing and a unused NVME 4.0 port open that wont affect any of my other lanes. Do I need/Use this?
I am considering a HBA SAS card but do I need this? I have a total of 5 drives and can add more if I order the HBA I would just order a couple more drives and fully populate the card. What do I gain from adding this to my system over the X570 chipset? Both have PCIe 4.0 So bandwidth is not a issue that I know of. The boot drive and Pool would be on the same chipset which could be a down side maybe? Do I gain speed, reliability, ease of use, better power consumption? I could run a total of 7 drives with the chipset and 8 drives with the HBA. These drives have gotten so cheap its hard not to go with more of them.
Any info anyone has will be greatly appreciated. If anyone has input on my server build to this point I would like to hear what you have to say. It will save me heart ache in the future. Thanks so much. I cant wait to get this running again and the TrueNas looks great from what I have seen so far. I also want to build a great Nas box so if you see anything wrong with what I am doing please speak up.
My build so far is.
AMD 5950X
