theSwedGuy
- Jul 7, 2021
Hey guys,
im new to TrueNas and really need your help. I try to transfer files to my NAS from my PC (windows 10 pro) but it constantly get interupted. Error 0x8007003B. I have looked through formus but have not found a solution. Its now so bad i cant use my nas anymore. Not a single file can be transfered without errors. They are all large 100gb ++
There are 4 pools with one disk in each. This is for testing purposes and later i thought that iwould have several disks per pool. It looks like the server does not like to have a disk at more than 80% capacity. And none of the disks that i transfer files to are @ that limit.
I have tried to turn off firewalls and antivirus in windows and also switched off Windows Serarch Service
What im i missing?
The system is:
AMD Ryzen 7 3700X 8-Core Processor
16GB ram
1GB network
And one LSI 9207 - splitting up for more SATA ports.
As for the storage issue. Im looking for a solution that i can expand, alot. I just have 40TB now but i expect it to be hundres of TB within a year or so. With so much need for space it seems that if i cant use 20% of the space because the server wont work, would this be the best solution for me then?
For my application raid might be too expensive so i thought i would just run it as JBOD. Idealy it would be several discs but just one big volume exposed to the Windows client.
What im i missing?
The system is:
16GB ram
1GB network
