Partition Report Metric "Wrong"
KazuyaDarklight
New to the system etc. v11.2
In our partition report, the numbers seem wrong and/or are so big they are nearly unusable/don't fit properly in the grid. As you can see below, it says gigabytes, but then gives this huge number. Our main pool is 49TB, so that should be in the region of 49000. The numbers are so big you can see it breaking the formatting at the bottom. This is on a full screen 24" monitor. So anything I can do here?
Chris Moore
