flashpoint
- Jan 8, 2016
Hey guys,
I am trying to rescan all my files on owncloud. I used an FTP client to upload about 100GB of data. I had a feeling that a browser/java would crash. Anyway. When I try to use hte ./occ command it says "Permission Denied"
I tried using "su www" as well as it is the owner the file, with no luck. It still gives me the same output.
"sudo ./occ" or "sudo /mnt/VOL1/jails/owncloud_1/usr/pbi/owncloud-amd64/www/owncloud occ" gives me an error as well. (file not found)
I don't know what to do, I can't rescan my folders so that means I have no access to them. Does anyone have an idea of what I should do?
oh and ps apparently there is no php installed and the web client some how works?
Thanks for your time and help!
[root@PE2950] /mnt/VOL1/jails/owncloud_1/usr/pbi/owncloud-amd64/www/owncloud# ./occ
CORRECT>./ocs (y|n|e|a)? yes
./ocs: Permission denied.
[root@PE2950] /mnt/VOL1/jails/owncloud_1/usr/pbi/owncloud-amd64/www/owncloud# php
php: Command not found.
