Hazimil
- May 26, 2014
As we now know, "CrashPlan for Home" ($60/month) is now being discontinued. So what are our options moving forward?
As I need to look into my options, I have done some quick research, and thought I share it here.
Please Note: I have no ties to any of the companies!
Migrate to a CrashPlan for Small Business ($10/month per device)
Pro: No need to install any different software (account change forces internal update to the client)
Pro: Works exactly the same as you are used to
Pro: Unlimited file versioning
Pro: Unlimited protection for deleted files (i.e. never removed)
Pro: NAS counts as “one device”
Pro: Unlimited storage
Con: Will only migrate up-to 5TB of data, so if you have more on your NAS you need to restart the whole backup afresh
Con: Only new/updated backups support the new AES-256 encryption, historical stuff stays on Blowfish encryption
Con: No more computer to computer backups (or computer to NAS backups), but you could replicate this with other free products
Carbonite ($59.99/year -> $149.99/year)
Con: Need to back-up everything again
Con: Basic tier doesn’t automatically backup Videos
Con: Large files (4GB+) must be manually added to backup
Con: No **NIX client, Windows only
Con: Limits backup files to anything under the windows "Users" folders, so will need “tweaking” to work on NAS (in a Windows VM)
Con: Only 3 months of file versioning
Con: Only 30 days protection for deleted files
BackBlaze ($50/year)
Con: Network drives (NAS drives) or folders shared from another computer not supported (but might be “tweakable” into a VM like we do with CrashPlan)
Con: Limits what file-type can be backed-up
Con: Only 30 days of file versioning
Con: Only 30 day protection for deleted files
BackBlaze B2 ($0.005/GB/month & $0.02/GB download charge)
Con: Need to use 3rd-party apps to back-up the data
Con: It’s a on-demand sync-copy, no file versioning/deleted file protection
Con: Download charge
Tarsnap ($0.25/GB storage/month & $0.25/GB bandwidth usage)
Pro: Supports FreeBSD (so should be simple to put in a Jail)
Pro&Con: Works by creating separate archives for each backup you do, thus some file deletion/retention based on how often you run your backup scripts.
Con: There is no graphical user interface, CLI only
Con: Need to be confident using shell scripts and CLI within FreeBSD
Con: No "live monitoring" of files
iDrive (Free -> $74.62/year)
Pro: 5GB Free
Pro: Supports **NIX (see Con)
Con: Storage is priced on a tiered basis, 2TB ($52.12/year), 5TB ($74.62/year) [can't see prices for higher tiers]
Con: For **NIX use you need to use a bundle of perl scripts (no client software)
SOS Online Backup ($44.99/year -> $2,999.99/year)
Pro?: NAS Support in "Home" version (but via network sharing to client PC)
Con: No **NIX client (but can backup via network shares....)
Con: Expensive! 50GB storage ($44.99/year) to 10TB storage ($2,999.99/year)
ElephantDrive (Free -> $9.95/month per TB)
Pro: 2GB free
Pro: Configurable file versioning control
Pro: Configurable delete files control
Pro: NAS support (Con: not FreeNAS)
Con: Gets expensive for large storage (many TB) needs
Con: 2GB limit on large file size
Jungle Disk ($5/month per server then $0.15/GB per month for storage)
Pro: Supports **NIX
Pro: Supports servers
Con: Minimal charge of $8/month per customer (so one server = $8/month)
Con: Large storage (i.e. TBs) gets expensive, i.e. 2TB = $300/month
OpenDrive ($9.95/month)
Pro: 5 GB free
Pro: File versioning
Pro?: Can map a Linux drive via WebDAV to the cloud (script backups?)
Con: Bandwidth limitations
Jottacloud (€7.5/month)
Pro: Supports NAS (but has to be done via Client on windows PC, but might be “tweakable” into a VM like we do with CrashPlan)
Con: Limited file versioning (last 5 copies only)
Other Options
I have tried to look for like-for-like options compare to CrashPlan for Home as thats what I am personally looking for. However another option is to just get some simple cloud storage, for example Google Cloud Storage, Dropbox, Google Drive, SpiderOak, Backblaze B2, Amazon S3, etc., and then use some software like RClone, Duplicati, GoodSync, Syncovery, Arq, etc. to backup your data. For this you need to do your own research I'm afraid, as Its not an option I'm looking at.
Conclusion so far:
I have decided to migrate to the "CrashPlan for Small Business" edition, as it still does everything I need. OK, it will cost an extra $60/year (excluding the short-term discounts), but $10/month is still cheap for protecting my NAS data.
I hope you found this useful?
Yours
Jonathan
Pro: 5GB Free
Pro: 2GB free
Pro: Supports **NIX
Pro: 5 GB free
Other Options
Conclusion so far:
Yours
Jonathan
