Kazuma
- Jan 27, 2019
I don't understand what crapped out or why. Was working a couple days ago and went to re-install plex because things wouldn't configure right and started getting errors. Clearly removing it didn't remove the error. I'm still getting the same code.
Thanks
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_plugin.py", line 646, in fetch_plugin_index
self.__clone_repo(git_server, git_working_dir)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_plugin.py", line 1222, in __clone_repo
porcelain.pull(destination, repo_url, errstream=devnull)
File "/usr/local/lib/python3.6/site-packages/dulwich/porcelain.py", line 826, in pull
r.reset_index(tree=tree)
File "/usr/local/lib/python3.6/site-packages/dulwich/repo.py", line 950, in reset_index
validate_path_element=validate_path_element)
File "/usr/local/lib/python3.6/site-packages/dulwich/index.py", line 530, in build_index_from_tree
obj, entry.mode, full_path, honor_filemode=honor_filemode)
File "/usr/local/lib/python3.6/site-packages/dulwich/index.py", line 460, in build_file_from_blob
os.chmod(target_path, mode)
PermissionError: [Errno 1] Operation not permitted: b'/mnt/storage/iocage/.plugin_index/backuppc.json'
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 128, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 88, in _run
return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 81, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 461, in list_resource
header=False)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 911, in fetch
icon=True, official=official)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_plugin.py", line 653, in fetch_plugin_index
_callback=self.callback)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 81, in logit
_callback(content, exception)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 64, in callback
raise callback_exception(message)
RuntimeError: [Errno 1] Operation not permitted: b'/mnt/storage/iocage/.plugin_index/backuppc.json'
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 161, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1109, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1046, in _call
return await self._call_worker(serviceobj, name, *args)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1073, in _call_worker
job,
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1004, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 989, in run_in_executor
Thanks
header=False)
job,
