Boot device failed, replacement was DOA, boot pool status is "replacing" and new device won't attach
Ben Waywood
I had 2 16GB USB drives as a mirrored boot environment, one boot device failed, when I attached it to the environment it worked for a few hours then went back to degraded so I assumed it was DOA, since then the boot pool status is "replacing" and the new device won't attach
Boot Pool Status
freenas-boot000DEGRADED
replacing000DEGRADED
/dev/da0p2000ONLINE
/dev/da0p2000UNAVAIL
Error after attach attempt
[EFAULT] concurrent.futures.process._RemoteTraceback: """ Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/zfs.py", line 132, in extend i['target'].attach(newvdev) File "libzfs.pyx", line 376, in libzfs.ZFS.__exit__ File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/zfs.py", line 132, in extend i['target'].attach(newvdev) File "libzfs.pyx", line 1289, in libzfs.ZFSVdev.attach libzfs.ZFSException: Can attach disks to mirrors and stripes only During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker r = call_item.fn(*call_item.args, **call_item.kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 131, in main_worker res = loop.run_until_complete(coro) File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete return future.result() File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 91, in _run return await self._call(name, serviceobj, methodobj, params=args, job=job) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 84, in _call return methodobj(*params) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 84, in _call return methodobj(*params) File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/zfs.py", line 135, in extend raise CallError(str(e), e.code) middlewared.service_exception.CallError: [EUNKNOWN] Can attach disks to mirrors and stripes only """ The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 332, in run await self.future File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 358, in __run_body rv = await self.middleware._call_worker(self.method_name, *self.args, job={'id': self.id}) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1062, in _call_worker return await self.run_in_proc(main_worker, name, args, job) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 996, in run_in_proc return await self.run_in_executor(self.__procpool, method, *args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 972, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) middlewared.service_exception.CallError: [EUNKNOWN] Can attach disks to mirrors and stripes only
CLOSE
My system
OS Version:
FreeNAS-11.2-U4.1
(Build Date: May 10, 2019 21:33)
Processor:
Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz (4 cores)
Memory:
32 GiB
Ben Waywood
D
dlavigne
Guest
Does a fresh install to a new boot device resolve the issue? If so, you can restore your config.
Ben Waywood
I am going to do that next. Can you confirm that if I go to System > General > Save Config then to a clean install and go to System > General > Upload Config it will restore everything including plugins, jails, VM's? Or is there another step to ensure everything restores correctly?
If you leave your data drives in the system, it will work as you describe.
pro lamer
Ben Waywood
I am back up and running now, there were a few dramas and I ended up using my windows machine to format the boot drives and had to try the install several times but eventually, it went through. Thanks for your help
