- now start the jail and console into it and run: ifconfig tun create. That should create an interface named tunX. When you configure that specific device in your openvpn config (dev tun0) you shouldn't get the error (Couldn't ... dynamic), you may, however, get some other error message.
the ticket for this bug was https://redmine.ixsystems.com/issues/40872
It is fixed for tun devices in 11.2 (enable the allow_tun option in the GUI) but not for tap devices. If you need a tap device edit
/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py
on the host and around line 700 search for
Code:if conf['allow_tun'] == '1': devfs_dict['tun*'] = None devfs_dict['tap*'] = None # add this to also enable tap devices
No, I still patch the code after every updateWas this fixed in the end? From the Jiira Issue https://jira.ixsystems.com/browse/NAS-100842 I can't really understand if it was fixed or not. Looking at the iocage code does not seem to.
I'm trying to put Zerotier in a jail and I get errors on the creation of tap interface.
Sigh
See what you've made me do, iXsystems...
Because of this automatic TAP adapter creation nonsense I've gone ahead and bought myself an HP T620 Plus to install pfsense on and run ACME, HAProxy, OpenVPN and pfBlockerNG.Still FreeBSD based... yay!
It's definitely better to have my FreeNAS box just handle SMB, iSCSI and backups (at which it is F*cking spectacular!!) and leave the rest for dedicated hardware with software and an OS that is superior for certain jobs and hassle-free without sacrificing features and functionality.
Gone are the days when I thought I could have literally everything running well and smoothly off a single "beefy" FreeNAS system (no GPU passthrough for Plex, bad VM performance & simple things don't always work...)
It's quite sad that the Bhyve VM system hasn't seemingly been overhauled/improved upon lately. Maybe TrueNAS has something interesting to offer seeing as running VMs through HyperV Manager on a WINDOWS 10 machine is more enjoyable at the moment than VMs on FreeNAS... a bit ridiculous really.
Rant over.![]()
I'd love to help you out but I haven't made the switch to TrueNAS Core yet.I love my pfSense that runs all that too. That is how I prefer it. But I am trying to get a project done where its just the freenas box. And for the life of me I cant figure out any of the options to get a solid vpn other than VM obuntu server 18.04 and the openvpn access server installed. Problem with that is limits on connections and resources to run in VM.. But it is easy to deploy and set up users. Prefer not to run in a vm. Truenas core has openvpn server in the services section but I cant get that to start either.
this did not work anymore for truenas 13.0the ticket for this bug was https://redmine.ixsystems.com/issues/40872
and edit as above
if check_truthy(conf['allow_tun']): devfs_dict['tun*'] = None if check_truthy(conf['allow_tun']): # add this for tap devices devfs_dict['tap*'] = None # add this for tap devices
... 2023-01-09 11:36:26 Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key 2023-01-09 11:36:26 Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key 2023-01-09 11:36:26 ROUTE_GATEWAY 192.168.9.1/255.255.255.0 IFACE=epair0b HWADDR=............ 2023-01-09 11:36:26 Cannot allocate TUN/TAP dev dynamically 2023-01-09 11:36:26 Exiting due to fatal error
openvpn --config /usr/local/etc/openvpn/plab.conf 2023-09-26 21:26:44 DEPRECATED OPTION: --cipher set to 'AES-256-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305). OpenVPN ignores --cipher for cipher negotiations. 2023-09-26 21:26:44 OpenVPN 2.6.5 amd64-portbld-freebsd12.4 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] 2023-09-26 21:26:44 library versions: OpenSSL 1.1.1q-freebsd 5 Jul 2022, LZO 2.10 2023-09-26 21:26:44 TCP/UDP: Preserving recently used remote address: [AF_INET]xxxxxxxxxxxxxxxxxxxxxxxxxxx:1194 2023-09-26 21:26:44 Socket Buffers: R=[42080->42080] S=[9216->9216] 2023-09-26 21:26:44 UDPv4 link local: (not bound) 2023-09-26 21:26:44 UDPv4 link remote: [AF_INET]xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx:1194 2023-09-26 21:26:44 TLS: Initial packet from [AF_INET]1xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx:1194, sid=xxxxxxxxxxxxxx xxxxxxxxxxxx 2023-09-26 21:26:44 VERIFY OK: depth=1, CN=Easy-RSA CA 2023-09-26 21:26:44 VERIFY KU OK 2023-09-26 21:26:44 Validating certificate extended key usage 2023-09-26 21:26:44 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication 2023-09-26 21:26:44 VERIFY EKU OK 2023-09-26 21:26:44 VERIFY OK: depth=0, CN=server 2023-09-26 21:26:44 Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 2048 bit RSA, signature: RSA-SHA256 2023-09-26 21:26:44 [server] Peer Connection Initiated with [AF_INETxxxxxxxxxxxxxxxxxxxxxxxxxxx:1194 2023-09-26 21:26:44 TLS: move_session: dest=TM_ACTIVE src=TM_INITIAL reinit_src=1 2023-09-26 21:26:44 TLS: tls_multi_process: initial untrusted session promoted to trusted 2023-09-26 21:26:45 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 2023-09-26 21:26:51 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 2023-09-26 21:26:51 PUSH: Received control message: 'PUSH_REPLY,redirect–gateway def1 bypass–dhcp,dhcp-option DNS 4.2.2.1,route 10.8.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.8.0.26 10.8.0.25,peer-id 3,cipher AES-256-GCM' 2023-09-26 21:26:51 OPTIONS IMPORT: --ifconfig/up options modified 2023-09-26 21:26:51 OPTIONS IMPORT: route options modified 2023-09-26 21:26:51 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 2023-09-26 21:26:51 ROUTE_GATEWAY 192.168.9.1/255.255.255.0 IFACE=epair0b HWADDR=xxxxxxxxxxxxxxxxxxxxxxxx 2023-09-26 21:26:51 Cannot allocate TUN/TAP dev dynamically <<<<<<<<<<<<<<<<<<<<!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 2023-09-26 21:26:51 Exiting due to fatal error
middleware just did not start anymore, i edited the file
/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_common.py at line 804
Code:if check_truthy(conf['allow_tun']): devfs_dict['tun*'] = None if check_truthy(conf['allow_tun']): # add this for tap devices devfs_dict['tap*'] = None # add this for tap devices
and it works again
ls -1 /usr/local/lib/ | grep python libpython3.9.so libpython3.9.so.1 libpython3.9.so.1.0 libpython3.9.so.1.0-gdb.py python3.9 cat /usr/local/lib/python3.9/site-packages/iocage_lib/ioc_common.py | grep tap if check_truthy(conf['allow_tun']): # add this for tap devices devfs_dict['tap*'] = None # add this for tap devices
jexec 843 bashCode:openvpn --config /usr/local/etc/openvpn/plab.conf ............... 2023-09-26 21:37:43 Cannot allocate TUN/TAP dev dynamically <<<<<<<<<<<<<<<<<<<<!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 2023-09-26 21:37:43 Exiting due to fatal error
Sigh
Rant over.![]()
