One or more devices has experienced an unrecoverable error
ITGuy1024
I logged in to my server today to check something and saw this error. Also apparently email alerts are broken but that's another issue.
"The volume PoolB state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected."
I checked my pools and they show healthy. Is there any diagnostics or way to gather more info about this? If I need to replace a drive I don't see where it shows me which one is failing.
HoneyBadger
actually does care
Administrator
SSH into the machine or open a shell and type zpool status -v
Post the result inside [CODE] [/CODE] tags for formatting. Look for errors in the READ/WRITE/CKSUM columns on each drive, check the line that talks about a scan/scrub.
ITGuy1024
state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
	   still be used, but some features are unavailable.
  scan: scrub repaired 0 in 0h2m with 0 errors on Wed Aug 15 13:02:27 2018
	   NAME											STATE	 READ WRITE CKSUM
	   PoolA										   ONLINE	   0	 0	 0
		 raidz1-0									  ONLINE	   0	 0	 0
		   gptid/fcdd10ed-8276-11e4-9022-40167e67c7a4  ONLINE	   0	 0	 0
		   gptid/fdbcfa1f-8276-11e4-9022-40167e67c7a4  ONLINE	   0	 0	 0
		   gptid/fe95d512-8276-11e4-9022-40167e67c7a4  ONLINE	   0	 0	 0
		   gptid/ff5789f5-8276-11e4-9022-40167e67c7a4  ONLINE	   0	 0	 0
errors: No known data errors
  pool: PoolB
 state: ONLINE
status: One or more devices has experienced an unrecoverable error.  An
   see: http://illumos.org/msg/ZFS-8000-9P
  scan: scrub repaired 0 in 18h49m with 0 errors on Thu Aug  2 18:49:23 2018
	   PoolB										   ONLINE	   0	 0	 0
		   gptid/2ca2e5d7-8669-11e4-88f8-40167e67c7a4  ONLINE	   0	 0	 0
		   gptid/2cdcb60f-8669-11e4-88f8-40167e67c7a4  ONLINE	   0	 0	 1
		   gptid/2d9de64f-8669-11e4-88f8-40167e67c7a4  ONLINE	   0	 0	 0
		   gptid/2e5d7e49-8669-11e4-88f8-40167e67c7a4  ONLINE	   0	 0	 0
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0h0m with 0 errors on Wed Aug 15 03:45:13 2018
	   freenas-boot  ONLINE	   0	 0	 0
		 ada4p2	ONLINE	   0	 0	 0
IceBoosteR
The error message indicated that there is a checksum error on your PoolB. This can be caused by various things. Have you checked your SMART data of your drives? I would start here and investigate where the error could come from.
Also have a look in /var/log/messages if there is anything which could explain the problem. Post the output here in codetags aswell.
HoneyBadger
actually does care
Administrator
That tells you that one drive experienced a checksum error, but ZFS did correct it from other data. It might be an early indication of a failing drive, or it might have just been an error that does happen - drives usually state their error rate as "1 in 10^14" or similar - and you just got unlucky.
Run glabel status - look for that gptid on the left, and find the device (eg: ada1) from the component (eg: ada1p2) then run smartctl -a /dev/ada1 against it and post result in tags.
ITGuy1024
glabel status
									 Name  Status  Components
gptid/fcdd10ed-8276-11e4-9022-40167e67c7a4	 N/A  ada0p2
gptid/fdbcfa1f-8276-11e4-9022-40167e67c7a4	 N/A  ada1p2
gptid/fe95d512-8276-11e4-9022-40167e67c7a4	 N/A  ada2p2
gptid/ff5789f5-8276-11e4-9022-40167e67c7a4	 N/A  ada3p2
gptid/f1428c05-ea98-11e7-bfaf-40167e67c7a4	 N/A  ada4p1
gptid/2ca2e5d7-8669-11e4-88f8-40167e67c7a4	 N/A  da0p2
gptid/2cdcb60f-8669-11e4-88f8-40167e67c7a4	 N/A  da1p2
gptid/2d9de64f-8669-11e4-88f8-40167e67c7a4	 N/A  da2p2
gptid/2e5d7e49-8669-11e4-88f8-40167e67c7a4	 N/A  da3p2
smartctl -a /dev/da1p2
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
/dev/da1p2: Unable to detect device type
Please specify device type with the -d option.
Use smartctl -h to get a usage summary
ITGuy1024
Vendor:			   HPT
Product:			  DISK 0_1
Revision:			 4.00
User Capacity:		3,000,592,982,016 bytes [3.00 TB]
Logical block size:   512 bytes
Device type:		  disk
Local Time is:		Wed Aug 15 15:34:32 2018 EDT
SMART support is:	 Unavailable - device lacks SMART capability.
Request Sense failed, [Input/output error]
Error Counter logging not supported
Device does not support Self Test logging
ITGuy1024
Well if SMART isn't available I'd say don't buy WD Red NAS drives...
HoneyBadger
actually does care
Administrator
That's your HighPoint controller (and it had better be in JBOD mode!) not the drive. You need to pass a device argument to smartctl in the format of
smartctl -a -d hpt,L/M/N /dev/da1
Where L is the controller ID, M is the channel number, and N is the PMPort number if used.
Try:
smartctl -a -d hpt,1/2 /dev/da1
ITGuy1024
Smartctl open device: /dev/da1 [hpt_disk_1/2/1] failed: Operation not permitted
HoneyBadger
actually does care
Administrator
I don't have a HighPoint card with me right now to poke around and find the right parameters to use unfortunately.
Basically you need to find a way to pull the SMART stats from that disk and see if there's any counters that are showing pre-failure indicators, the first culprits usually being 197 Current_Pending_Sector and 198 Offline_Uncorrectable.
If there aren't any, or the values are low, you can issue a zpool clear against the device and it should reset the value, but keep a close eye on it and if it pops up again, consider replacing the drive.
zpool clear PoolB gptid/2cdcb60f-8669-11e4-88f8-40167e67c7a4
The lack of SMART data though is a concern because regular SMART tests will pick up stuff like this, and they're an excellent additional measure to ensure the health of your pool.
Chris Moore
As a test, can you connect that individual drive to a regular SATA port so we can get SMART data out of it? If the RocketRaid card didn't do anything crazy to your drive, it should work just as well from a regular SATA port.
HoneyBadger
actually does care
Administrator
Here's a very old thread about Highpoint controllers from @cyberjock
https://forums.freenas.org/index.php?threads/highpoint-controller-info.8217/
Note: SMART data and serial numbers are NOT currently working with ANY Highpoint controllers. This is a feature that is being actively pursued by [Cyberjock] and William Grzybowski(developer). Serial and SMART may or may not work ever.
That was in 2012; and there's still no SMART data coming through Highpoint controllers. I'd strongly suggest putting that card where it belongs (in the trash ;) ) and getting an LSI-based HBA.
(Alternatively you could try shooting a Highpoint with a Hi-Point and see if those two respective piles of garbage can collaborate on something useful for once.)
Chris Moore
PS. Do you have a hardware budget / is this your system or a client system?
ITGuy1024
This is my system. I was on a budget when I built it say 4 years ago, and I had all the parts laying around already. But these days spending money on it wouldn't be an issue.
Point taken ;)
Chris Moore
Were you able to move the suspect drive to a standard SATA port so we can check the SMART status?
Chris Moore
I would suggest changing from the two RocketRaid cards to this LSI chip based card:
HP H220 6Gbps SAS PCI-E 3.0 HBA LSI 9207-8i P20 IT Mode for ZFS FreeNAS unRAID
https://www.ebay.com/itm/162862201664
and you may need a set of these cables to go with it:
Drive Cables: Mini SAS to 4-SATA SFF-8087 Multi-Lane Forward Breakout Internal Cable - - US $12.99
https://www.ebay.com/itm/371681252206
ITGuy1024
I wasn't able to do that.
Seems like a pretty good option. The prices have come down on those cards a bit since the last time I looked at them. What's the max breakout you can have from one of those mini sas ports?
Chris Moore
The card can support 256 drives if I recall correctly, but you need SAS expanders for it. Each port is four SAS lanes and, kind of like a network switch does for Ethernet, the SAS expander breaks that connectivity out to many drives. One of the systems I run at work has 4 expanssion chassis connected with 16 drives in each, but you can go higher than that easily. I can give you some guidance if you are looking to build your own or if you plan to buy a factory built chassis. There are so many options.
