Viktor Westin
 - Apr 18, 2016
Hey there!
I'm rather new to FreeNAS, and I'm afraid it might be judgement day for my decision to choose the cheap path and go non-ECC last January when i purchased my parts. I've got my system up and running and worked around some hiccups since then, but I can't say I'm very confident in working with FreeNAS as of yet. Bear with me, please.
Anyways, I just realized something's wrong with the system. I get an alert saying the following:
CRITICAL: Nov. 2, 2016, 2:47 p.m. - The boot volume state is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
Now, I've found out one first move is to check shell for the output of the following command:
I got:
So I gather as much as that this is related to my boot-drive having some issues. I recently updated to 9.10.1-U2, and today, when I saw this error, activated my previous 9.10.1. However, this didn't do anything. As you guys probably might've expected :) However, my guess is that my data is currently safe?
Bearing in mind my limited knowledge, what do you guys say is the problem, and how do I fix it?
Thanks in advance!
 zpool status -vI got:
pool: NAS state: ONLINE scan: scrub repaired 0 in 2h55m with 0 errors on Sun Oct 9 02:55:32 2016 config: NAME STATE READ WRITE CKSUM NAS ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 gptid/0c1ad385-e9f6-11e5-bfe4-408d5cb0394b ONLINE 0 0 0 gptid/0d127043-e9f6-11e5-bfe4-408d5cb0394b ONLINE 0 0 0 errors: No known data errors pool: PlexJail state: ONLINE scan: scrub repaired 0 in 0h1m with 0 errors on Sun Oct 23 00:01:33 2016 config: NAME STATE READ WRITE CKSUM PlexJail ONLINE 0 0 0 gptid/52370aa1-d70d-11e5-93ce-408d5cb0394b ONLINE 0 0 0 errors: No known data errors pool: freenas-boot state: ONLINE status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: http://illumos.org/msg/ZFS-8000-8A scan: scrub repaired 0 in 0h12m with 5 errors on Fri Oct 28 03:57:03 2016 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 gptid/c330cd95-d74b-11e5-81d7-408d5cb0394b ONLINE 0 0 0 errors: Permanent errors have been detected in the following files: freenas-boot/ROOT/9.10.1@2016-05-10-10:54:34:/usr/share/man/man3/isxdigit.3.gz freenas-boot/ROOT/9.10.1@2016-05-10-10:54:34:/usr/share/man/man3/isideogram.3.gz freenas-boot/ROOT/9.10.1@2016-05-10-10:54:34:/usr/share/man/man3/isphonogram.3.gz freenas-boot/ROOT/9.10.1@2016-05-10-10:54:34:/usr/share/man/man3/ispunct_l.3.gz freenas-boot/ROOT/9.10.1@2016-02-19-13:11:38:/var/db/pkg/local.sqlite
Thanks in advance!
