ThatITNoob
- Mar 25, 2023
Hi everyone,
I have been reading through the forums and other sources to familiarize myself with TrueNAS.
I have an old rig that I would love to utilize as a NAS.
Definitely looking forward to an opinion discussion, thanks in advance for your help!
CPU: Ryzen 2700x.
MOBO: Crosshair Hero VII (Wi-Fi)
RAM: Need some help as I'm kind of confused with the specs for the Mobo. An extra pair of eyes would be nice.
PSU: EVGA 1000 G Gold 80 Plus
Hard Drives: (2) 12TB Drives, looking to add an additional 2 (12TB) Drives within the future.
Case: Rosewill Blackhawk Ultra (Potentially looking to expand my drive usage to fill all 10 slots that are available).
*I have two 1TB SSDs and may want to use one. Would this be necessary or overkill for the TrueNAS OS or is the proper way still USB?
If so, I can look for a smaller 120GB SSD.
*I'm a bit stuck looking for ECC RAM. Seems like it's a double-edged sword with AMD and ECC RAM and I'm not certain which RAM to look for or what not within the specs for my motherboard.
*Hard Drives will be ran in storage pools within TrueNAS, as I'm not sure which yet; still looking. Could I start with two drives and add two more to the storage pool without issues?
Memory info for motherboard:
4 x DIMM, Max. 64GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
4 x DIMM, Max. 64GB, DDR4 3400(O.C.)/3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
AMD 7th Generation A-Series/Athlon X4 Processors
4 x DIMM, Max. 64GB, DDR4 2400/2133 MHz Un-buffered Memory
AMD Ryzen™ 2nd Generation Processors
AMD Ryzen™ 2nd Generation/ Ryzen™ with Radeon™ Vega Graphics/ Athlon™ with Radeon™ Vega Graphics/ Ryzen™ 1st Generation Processors
Dual Channel Memory Architecture
4 x DIMM, Max. 64GB, DDR4 2400/2133 MHz Un-buffered Memory < to clarify, would I need a newer CPU for the ECC RAM or would I be able to locate the specific RAM and not have any issues?
CPU: Ryzen 2700x.
