mcscooby41
- May 13, 2022
I've recently purchase a dual 1GB Intel I340 NIC and installed it into my TrueNAS Scale device, I plugged both ports and the onboard NIC from the motherboard into the same switch.
I added the two new NIC's to the same bridge group as the onboard NIC and all 3 showed as 1GB links and as up, I could then unplug a NIC at random and see the traffic move between ports. Overnight the two ports on the Intel NIC are now showing as no link & only 100MB speed on the switch. Rebooting the server, unplugging the cables and swapping with a known good one on a known good port on the switch fails to bring either port back online.
Any ideas on what I might be missing here? Is there a way to force the link up in TrueNAS Scale?
I'm running:-
TrueNAS-SCALE-22.12.3.3
Cheers
I'm running:-
Cheers
