itsryan
- Jan 11, 2017
My main problem is my VGA port on my motherboard broke off and the board is not under warranty so I needed to look for a alterative solution to be able to see my local output. I got a Nvidia Quadro p400 to hopefully fix this problem. The card is installed but I get no source when trying to see any video. I am able to see the card when I run commands like lspci -v.
I am thinking maybe it needs a driver so i tried to install Nvidia drivers. As per the security in truenas, pkg wont work unless its in a jail.
When I try the command nvidia-smi I get "nvidia-smi: Command not found."
How can I use the new card for video output from the server?
Edit: my motherboard dose not support IPMI
