nemisisak
- Jun 19, 2015
Hey,
Having a few problems. One of my disks failed from my 6x3Tb Z1 raid. So I decided I would take the opportunity to expand my pool and implement Z2 redundency.
All of the drives are Seagate ST3000DM001 Barracudas. Out of a mere few quid difference I bought 3 additional Toshiba 3Tb DT01ACA300 drives.
Once they arrived I banged them in, destroyed my old pool, created the new one and restored from my backup. Once that completed I was getting alot of errors due to unreadable sectors from ada1 + ada5. So I ran a long SMART test on each and then scrubed my pool. This is what im left with:
Jan 12 21:32:29 freenas smartd[2831]: Device: /dev/ada1, 320 Currently unreadable (pending) sectors
Jan 12 21:32:29 freenas smartd[2831]: Device: /dev/ada5, 672 Currently unreadable (pending) sectors
I have been looking up a lot on stuff related to this mess but im a little lost.
Some people have suggested force writing to the bad sectors to reallocate them using -
However this seems rather sketchy and I dont understand how the code will work as its writing nonsensical data to my pool.
Also I could just use 'zpool clear' but again I dont think this solves anything.
While I WILL be buying new drives and returning these ones I would really appreciate a little explanation on this issue.
Thank you :)
EDIT//- I am also going to run a long smart test on the 3rd Toshiba drive (as these all came from the same supplier) as I only have a Z2 raid I dont particually want problems with this one aswell in the mean time.
Could you also advise if I should resilver or restore from my backup(therefore destroy + recreate my pool)?
- CRITICAL: Device: /dev/ada5, 32 Currently unreadable (pending) sectors
- CRITICAL: Device: /dev/ada5, Self-Test Log error count increased from 0 to 1
- CRITICAL: Device: /dev/ada5, ATA error count increased from 179 to 265
- CRITICAL: Device: /dev/ada1, 104 Currently unreadable (pending) sectors
- CRITICAL: Device: /dev/ada1, Self-Test Log error count increased from 0 to 1
- CRITICAL: Device: /dev/ada1, ATA error count increased from 250 to 305
- CRITICAL: The volume AllDiskVolume (ZFS) state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.
[root@freenas] ~# smartctl -a /dev/ada1
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p28 amd64] (local build)
Model Family: Toshiba 3.5" DT01ACA... Desktop HDD
Device Model: TOSHIBA DT01ACA300
Serial Number: 55D64D5GS
LU WWN Device Id: 5 000039 fe3c2cab7
Firmware Version: MX6OABB0
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Jan 12 21:32:20 2016 GMT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
data collection: (22222) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 371) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 139 139 054 Pre-fail Offline - 70
3 Spin_Up_Time 0x0007 100 100 024 Pre-fail Always - 0
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 3
5 Reallocated_Sector_Ct 0x0033 018 018 005 Pre-fail Always - 1618
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 124 124 020 Pre-fail Offline - 33
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 74
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 3
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 4
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 4
194 Temperature_Celsius 0x0002 193 193 000 Old_age Always - 31 (Min/Max 20/35)
196 Reallocated_Event_Count 0x0032 019 019 000 Old_age Always - 1623
197 Current_Pending_Sector 0x0022 093 093 000 Old_age Always - 320
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
ATA Error Count: 7817 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 7817 occurred at disk power-on lifetime: 63 hours (2 days + 15 hours)
ER ST SC SN CL CH DH
40 51 18 40 cc 51 0c Error: WP at LBA = 0x0c51cc40 = 206687296
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
61 08 08 b0 d9 75 40 00 2d+14:48:03.700 WRITE FPDMA QUEUED
60 28 00 48 26 52 40 00 2d+14:48:03.700 READ FPDMA QUEUED
60 30 f8 28 cc 51 40 00 2d+14:48:03.700 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 2d+14:48:03.696 READ LOG EXT
61 08 f8 b0 d9 75 40 00 2d+14:48:00.247 WRITE FPDMA QUEUED
Error 7816 occurred at disk power-on lifetime: 63 hours (2 days + 15 hours)
60 28 f0 48 26 52 40 00 2d+14:48:00.247 READ FPDMA QUEUED
60 30 e8 28 cc 51 40 00 2d+14:48:00.247 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 2d+14:48:00.243 READ LOG EXT
60 28 e0 48 26 52 40 00 2d+14:47:56.935 READ FPDMA QUEUED
Error 7815 occurred at disk power-on lifetime: 63 hours (2 days + 15 hours)
40 51 18 40 cc 51 0c Error: UNC at LBA = 0x0c51cc40 = 206687296
60 30 d8 28 cc 51 40 00 2d+14:47:56.935 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 2d+14:47:56.931 READ LOG EXT
60 28 d8 48 26 52 40 00 2d+14:47:53.424 READ FPDMA QUEUED
60 30 d0 28 cc 51 40 00 2d+14:47:53.424 READ FPDMA QUEUED
Error 7814 occurred at disk power-on lifetime: 63 hours (2 days + 15 hours)
2f 00 01 10 00 00 00 00 2d+14:47:53.421 READ LOG EXT
60 28 d0 48 26 52 40 00 2d+14:47:49.992 READ FPDMA QUEUED
60 30 c8 28 cc 51 40 00 2d+14:47:49.959 READ FPDMA QUEUED
Error 7813 occurred at disk power-on lifetime: 63 hours (2 days + 15 hours)
60 28 c0 10 f6 38 40 00 2d+14:47:49.950 READ FPDMA QUEUED
60 30 b8 80 da 52 40 00 2d+14:47:49.949 READ FPDMA QUEUED
60 28 b0 08 bf 39 40 00 2d+14:47:49.949 READ FPDMA QUEUED
# 1 Extended offline Completed: read failure 90% 26 445515648
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.Code:
[root@freenas] ~# smartctl -a /dev/ada5
Serial Number: 55D5VS5GS
LU WWN Device Id: 5 000039 fe3c2aa43
Local Time is: Tue Jan 12 21:35:15 2016 GMT
command.
power-saving mode.
5 Reallocated_Sector_Ct 0x0033 050 050 005 Pre-fail Always - 981
194 Temperature_Celsius 0x0002 171 171 000 Old_age Always - 35 (Min/Max 23/39)
196 Reallocated_Event_Count 0x0032 054 054 000 Old_age Always - 1009
197 Current_Pending_Sector 0x0022 073 073 000 Old_age Always - 672
ATA Error Count: 5325 (device log contains only the most recent five errors)
Error 5325 occurred at disk power-on lifetime: 61 hours (2 days + 13 hours)
40 51 58 18 da 74 0b Error: UNC at LBA = 0x0b74da18 = 192207384
60 e0 e0 70 da 74 40 00 2d+13:15:08.141 READ FPDMA QUEUED
60 e0 d8 90 d9 74 40 00 2d+13:15:08.141 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 2d+13:15:08.137 READ LOG EXT
60 e0 d8 70 da 74 40 00 2d+13:15:04.298 READ FPDMA QUEUED
60 e0 d0 90 d9 74 40 00 2d+13:15:04.298 READ FPDMA QUEUED
Error 5324 occurred at disk power-on lifetime: 61 hours (2 days + 13 hours)
2f 00 01 10 00 00 00 00 2d+13:15:04.294 READ LOG EXT
60 e0 d0 70 da 74 40 00 2d+13:15:00.430 READ FPDMA QUEUED
60 e0 c8 90 d9 74 40 00 2d+13:15:00.430 READ FPDMA QUEUED
Error 5323 occurred at disk power-on lifetime: 61 hours (2 days + 13 hours)
2f 00 01 10 00 00 00 00 2d+13:15:00.426 READ LOG EXT
60 e0 c8 70 da 74 40 00 2d+13:14:56.579 READ FPDMA QUEUED
60 e0 c0 90 d9 74 40 00 2d+13:14:56.579 READ FPDMA QUEUED
Error 5322 occurred at disk power-on lifetime: 61 hours (2 days + 13 hours)
2f 00 01 10 00 00 00 00 2d+13:14:56.575 READ LOG EXT
60 e0 c0 70 da 74 40 00 2d+13:14:52.726 READ FPDMA QUEUED
60 e0 b8 90 d9 74 40 00 2d+13:14:52.726 READ FPDMA QUEUED
Error 5321 occurred at disk power-on lifetime: 61 hours (2 days + 13 hours)
60 e0 b0 b0 d8 74 40 00 2d+13:14:52.725 READ FPDMA QUEUED
60 e0 a8 d0 d7 74 40 00 2d+13:14:52.725 READ FPDMA QUEUED
60 e0 a0 f0 d6 74 40 00 2d+13:14:52.725 READ FPDMA QUEUED
# 1 Extended offline Completed: read failure 90% 26 451632936
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
sysctl kern.geom.debugflags=16 dd if=/dev/zero of=/dev/adaX bs=4096 count=1 seek=451632936 conv=noerror,sync
Thank you :)
