Hi everyone,
I am currently using a QNAP TS-251+ with 8GB Ram most for PLEX however even tough i like the OS interface and easy usage/accessibility, i am not satisfied with its performance. It has an Intel J1900 cpu which is old and weak.
I am getting a NUC7 with i3-7100U to build my own NAS (dont know if i can call it a real NAS) and it will have 8 GB ram (w/ ECC) however i couldnt decide on 2 things;
1- which OS to use? i am debating between w10 and FreeNAS, would like to try FreeNAS but i dont want to get a small drive and once i dont like it, then i need to get a bigger capacity to install w10.
2- what capacity SSD to use with it.
I like QNAPs interface where i can connect to it via my android phone, add downloads, access move my files and so on. Mainly i will use to play media via PMS
As i heard and saw from the videos, once FreeNAS is installed on the drive, i cant use the drive as a storage option, right? so how much space i need to install and run freeNAS? 16GB m2.SSD will be enough? or more? I will have my media files on external drive via 3.0 or 3.1
I think i am just bored and looking to try new stuff
thanks in advance
thanks in advance
