jcl123
- Jul 6, 2019
Hello all,
I was running a QNAP TS-1079-PRO (10-bay) for a number of years, and then recently the backplane died. QNAP support said they don't make them anymore, and even if they did they would not sell me one (I would have to ship the whole unit for a 10-minute fix). So, in any case I am not going to reward them with buying another one, the first one was almost $3K without disks, so it was a bit of a leap to begin with.
All is not lost, the 10-bay box does a good job keeping drives cool, so I am converting it into an external JBOD enclosure and looking at FreeNAS. Note that some of my parts are older because I am re-using things from the QNAP that are still perfectly good (CPU, RAM, etc.). While other parts are current as I added them recently from ebay or whatever. I believe in buying high as I end up getting that many more years out of things to re-use.
Here is what I have so far:
Case(s): Fractal Design Define R6 (11x 3.5 drive capacity) + QNAP box with 10 bays JBOD
Motherboard: Supermicro X9SCM-F
CPU: Xeon E3-1245 ("v0")
RAM: Currently 16GB DDR3 ECC, will upgrade to 32GB.
Boot drive: Sandisk consumer 128GB SSD, I could use two of these for mirroring in needed
HBA: Broadcom/LSI 9400-16i tri-mode 12Gig SAS HBA
SAS expander: Intel res3tv360 located in QNAP box
NIC: Intel x550 10Gig + the on-board 1Gig NICs on the M/B
Disks: 9x WD RED 3TB drives
Of course there is a ton of cabling and fans in this build that I will detail if needed.
About me / experience level:
I am an experienced (20+ years) IT engineer mostly in Windows and VMware, but I have wanted to try out FreeNAS for awhile, so this looks like my chance.
Device use cases:
- As a backup device for my primary server (Windows Sersver 2019 Storage Spaces / ReFS build)
- As a transmission server host (one of the things the QNAP did well)
- Data is primarily 1080p and 4K home video, as well as pictures, lately I am now doing some 360-degree VR video as well
- I am debating going bare-metal or ESXi w/pass-thru, because then I could also run my pFsense router on the same box
Notes:
- I have 10Gig because I want to be able to backup 16TB or so without it taking a week
- The QNAP easily saturated a 1Gig link, I didn't get a chance to test 10Gig before the back-plane died
- I have so many disk ports (21x 3.5" not including 2.5") because the backup server tends to use older disks I re-purpose, so I need more
- Server is protected by an APC UPS and my house has Tesla Powerwall storage batteries and solar, in case the question comes up
Questions:
* Would you recommend having two boot devices? (add a 2nd SSD, they are cheap)
* I currently have a bunch of 3TB disks, can ZFS deal with mixed disk sizes?
Thank you very much in advance
-JCL
Device use cases:
Notes:
Questions:
- e.g. should I just buy more 3TB disks, or can I start buying 8TB disks or something?
- On my Windows Storage Spaces server I am using 7x "shucked" 10TB WD drives from USB enclosures
- I imagine you could have multiple different pools or something like that, probably there is a long explanation to that
* Would you recommend SSD cache disks?- I am prepared to add eSSDs if needed, but I have read articles both for and against in this use case, so I am not sure
- Any other advice or recommendations that you think this build needs?
-JCL
