After getting a little fed up with running zfs as a module over in linux-land, I upgraded to TrueNAS Core using the same hardware. I have no previous experience with freebsd/freenas/truenas.  I appreciate how mostly turn-key the OS is.
It's been a couple months of usage, and I'm noticing very infrequent errors on the console.
The error occurs like clockwork on the same day of the week (sunday) but this is neither the day my smart tests are scheduled nor the day the scrub is scheduled.
I'm running a pair of these old WD red drives and a similarly-sized seagate ST3000DM001.
I've not noticed any actual issues with the performance of the NAS since switching from Linux, and I hadn't found any errors in smartctl before this reinstallation. I haven't seen any obvious red flags on the dashboard as well. I'm also a bit of a novice as I haven't had any issues with the hardware over the past years so I'm not too certain what this error means. I'm inclined to think it's matching a scheduled task of some kind, but as I said before the tasks occur on a different day from the smart test and scrub schedules.
Feb 4 00:00:00 truenas syslog-ng[1311]: Configuration reload finished; Feb 4 22:33:07 truenas (ada2:ahcich4:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 28 48 32 a3 40 c3 00 00 00 00 00 Feb 4 22:33:07 truenas (ada2:ahcich4:0:0:0): CAM status: ATA Status Error Feb 4 22:33:07 truenas (ada2:ahcich4:0:0:0): ATA status: 41 (DRDY ERR), error: 10 (IDNF ) Feb 4 22:33:07 truenas (ada2:ahcich4:0:0:0): RES: 41 10 48 32 a3 40 c3 00 00 00 00 Feb 4 22:33:07 truenas (ada2:ahcich4:0:0:0): Retrying command, 3 more tries remain
root@truenas[~]# smartctl -x /dev/ada2
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p7 amd64] (local build)
Model Family:     Western Digital Red
Device Model:     WDC WD30EFRX-68EUZN0
Serial Number:    WD-WMC4N1013948
LU WWN Device Id: 5 0014ee 0590502c9
Firmware Version: 80.00A80
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Sat Feb 10 18:05:19 2024 EST
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, frozen [SEC2]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (40980) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 411) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x703d) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR-K   200   200   051    -    0
  3 Spin_Up_Time            POS--K   179   175   021    -    6008
  4 Start_Stop_Count        -O--CK   100   100   000    -    91
  5 Reallocated_Sector_Ct   PO--CK   200   200   140    -    0
  7 Seek_Error_Rate         -OSR-K   200   200   000    -    0
  9 Power_On_Hours          -O--CK   057   057   000    -    31919
 10 Spin_Retry_Count        -O--CK   100   253   000    -    0
 11 Calibration_Retry_Count -O--CK   100   253   000    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    91
192 Power-Off_Retract_Count -O--CK   200   200   000    -    19
193 Load_Cycle_Count        -O--CK   121   121   000    -    239316
194 Temperature_Celsius     -O---K   131   119   000    -    19
196 Reallocated_Event_Count -O--CK   200   200   000    -    0
197 Current_Pending_Sector  -O--CK   200   200   000    -    0
198 Offline_Uncorrectable   ----CK   100   253   000    -    0
199 UDMA_CRC_Error_Count    -O--CK   200   200   000    -    0
200 Multi_Zone_Error_Rate   ---R--   200   200   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      6  Ext. Comprehensive SMART error log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa0-0xa7  GPL,SL  VS      16  Device vendor specific log
0xa8-0xb7  GPL,SL  VS       1  Device vendor specific log
0xbd       GPL,SL  VS       1  Device vendor specific log
0xc0       GPL,SL  VS       1  Device vendor specific log
0xc1       GPL     VS      93  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 3
        CR     = Command Register
        FEATR  = Features Register
        COUNT  = Count (was: Sector Count) Register
        LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
        LH     = LBA High (was: Cylinder High) Register    ]   LBA
        LM     = LBA Mid (was: Cylinder Low) Register      ] Register
        LL     = LBA Low (was: Sector Number) Register     ]
        DV     = Device (was: Device/Head) Register
        DC     = Device Control Register
        ER     = Error register
        ST     = Status register
Error 3 [2] occurred at disk power-on lifetime: 31779 hours (1324 days + 3 hours)
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  10 -- 51 00 00 00 00 c3 a3 32 48 40 00  Error: IDNF at LBA = 0xc3a33248 = 3282252360
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  61 00 28 00 00 00 00 c3 a3 32 48 40 08 27d+15:03:48.560  WRITE FPDMA QUEUED
  ea 00 00 00 00 00 00 00 00 00 00 40 08 27d+15:02:49.142  FLUSH CACHE EXT
  61 00 08 00 f0 00 01 5d 50 a1 c0 40 08 27d+15:02:49.141  WRITE FPDMA QUEUED
  61 00 08 00 e8 00 01 5d 50 9f c0 40 08 27d+15:02:49.141  WRITE FPDMA QUEUED
  61 00 08 00 e0 00 00 00 40 03 c0 40 08 27d+15:02:49.141  WRITE FPDMA QUEUED
Error 2 [1] occurred at disk power-on lifetime: 31430 hours (1309 days + 14 hours)
  10 -- 51 00 00 00 00 74 ed af d8 40 00  Error: IDNF at LBA = 0x74edafd8 = 1961734104
  61 00 40 00 88 00 00 74 ed af d8 40 08 13d+01:41:02.649  WRITE FPDMA QUEUED
  ea 00 00 00 00 00 00 00 00 00 00 40 08 13d+01:40:02.978  FLUSH CACHE EXT
  61 00 08 00 78 00 01 5d 50 a2 10 40 08 13d+01:40:02.977  WRITE FPDMA QUEUED
  61 00 08 00 70 00 01 5d 50 a0 10 40 08 13d+01:40:02.977  WRITE FPDMA QUEUED
  61 00 08 00 68 00 00 00 40 04 10 40 08 13d+01:40:02.977  WRITE FPDMA QUEUED
Error 1 [0] occurred at disk power-on lifetime: 31263 hours (1302 days + 15 hours)
  10 -- 51 00 00 00 00 64 92 91 28 40 00  Error: IDNF at LBA = 0x64929128 = 1687327016
  61 00 68 00 68 00 00 64 92 91 28 40 08  6d+02:17:41.723  WRITE FPDMA QUEUED
  ea 00 00 00 00 00 00 00 00 00 00 40 08  6d+02:17:32.553  FLUSH CACHE EXT
  61 00 08 00 58 00 01 5d 50 a1 e8 40 08  6d+02:17:32.552  WRITE FPDMA QUEUED
  61 00 08 00 50 00 01 5d 50 9f e8 40 08  6d+02:17:32.552  WRITE FPDMA QUEUED
  61 00 08 00 48 00 00 00 40 03 e8 40 08  6d+02:17:32.552  WRITE FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Short offline       Completed without error       00%     31784         -
# 2  Short offline       Completed without error       00%     31616         -
# 3  Short offline       Completed without error       00%     31449         -
# 4  Short offline       Completed without error       00%     31281         -
# 5  Short offline       Completed without error       00%     31113         -
# 6  Short offline       Completed without error       00%     30945         -
# 7  Short offline       Completed without error       00%     30777         -
# 8  Short offline       Completed without error       00%     30609         -
# 9  Short offline       Completed without error       00%     30441         -
#10  Short offline       Completed without error       00%     30273         -
#11  Short offline       Completed without error       00%     30106         -
#12  Short offline       Completed without error       00%     29938         -
#13  Extended offline    Completed without error       00%        19         -
SCT Status Version:                  3
SCT Version (vendor specific):       258 (0x0102)
Device State:                        Active (0)
Current Temperature:                    19 Celsius
Power Cycle Min/Max Temperature:     17/24 Celsius
Lifetime    Min/Max Temperature:     12/31 Celsius
Under/Over Temperature Limit Count:   0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/60 Celsius
Min/Max Temperature Limit:           -41/85 Celsius
Temperature History Size (Index):    478 (3)
Index    Estimated Time   Temperature Celsius
   4    2024-02-10 10:08    19  -
 ...    ..(318 skipped).    ..  -
 323    2024-02-10 15:27    19  -
 324    2024-02-10 15:28    20  *
 325    2024-02-10 15:29    19  -
 ...    ..(  2 skipped).    ..  -
 328    2024-02-10 15:32    19  -
 329    2024-02-10 15:33    20  *
 330    2024-02-10 15:34    19  -
 333    2024-02-10 15:37    19  -
 334    2024-02-10 15:38    20  *
 335    2024-02-10 15:39    19  -
 336    2024-02-10 15:40    19  -
 337    2024-02-10 15:41    20  *
 338    2024-02-10 15:42    19  -
 339    2024-02-10 15:43    20  *
 340    2024-02-10 15:44    19  -
 341    2024-02-10 15:45    19  -
 342    2024-02-10 15:46    20  *
 343    2024-02-10 15:47    19  -
 344    2024-02-10 15:48    20  *
 345    2024-02-10 15:49    19  -
 346    2024-02-10 15:50    19  -
 347    2024-02-10 15:51    20  *
 348    2024-02-10 15:52    19  -
 349    2024-02-10 15:53    20  *
 350    2024-02-10 15:54    19  -
 353    2024-02-10 15:57    19  -
 354    2024-02-10 15:58    20  *
 355    2024-02-10 15:59    19  -
 356    2024-02-10 16:00    19  -
 357    2024-02-10 16:01    20  *
 358    2024-02-10 16:02    19  -
 359    2024-02-10 16:03    20  *
 360    2024-02-10 16:04    19  -
 361    2024-02-10 16:05    19  -
 362    2024-02-10 16:06    20  *
 363    2024-02-10 16:07    19  -
 364    2024-02-10 16:08    20  *
 365    2024-02-10 16:09    19  -
 366    2024-02-10 16:10    19  -
 367    2024-02-10 16:11    20  *
 368    2024-02-10 16:12    19  -
 369    2024-02-10 16:13    20  *
 370    2024-02-10 16:14    19  -
 371    2024-02-10 16:15    19  -
 372    2024-02-10 16:16    20  *
 373    2024-02-10 16:17    19  -
 374    2024-02-10 16:18    20  *
 375    2024-02-10 16:19    19  -
 376    2024-02-10 16:20    19  -
 377    2024-02-10 16:21    20  *
 378    2024-02-10 16:22    19  -
 379    2024-02-10 16:23    20  *
 380    2024-02-10 16:24    19  -
 381    2024-02-10 16:25    19  -
 382    2024-02-10 16:26    20  *
 383    2024-02-10 16:27    19  -
 384    2024-02-10 16:28    20  *
 385    2024-02-10 16:29    19  -
 386    2024-02-10 16:30    19  -
 387    2024-02-10 16:31    20  *
 388    2024-02-10 16:32    19  -
 389    2024-02-10 16:33    20  *
 390    2024-02-10 16:34    19  -
 391    2024-02-10 16:35    19  -
 392    2024-02-10 16:36    20  *
 393    2024-02-10 16:37    19  -
 396    2024-02-10 16:40    19  -
 397    2024-02-10 16:41    20  *
 398    2024-02-10 16:42    19  -
 401    2024-02-10 16:45    19  -
 402    2024-02-10 16:46    20  *
 403    2024-02-10 16:47    19  -
 404    2024-02-10 16:48    20  *
 405    2024-02-10 16:49    19  -
 406    2024-02-10 16:50    20  *
 407    2024-02-10 16:51    20  *
 408    2024-02-10 16:52    19  -
 ...    ..(  7 skipped).    ..  -
 416    2024-02-10 17:00    19  -
 417    2024-02-10 17:01    20  *
 418    2024-02-10 17:02    19  -
 419    2024-02-10 17:03    20  *
 420    2024-02-10 17:04    19  -
 421    2024-02-10 17:05    20  *
 422    2024-02-10 17:06    20  *
 423    2024-02-10 17:07    19  -
 424    2024-02-10 17:08    19  -
 425    2024-02-10 17:09    20  *
 426    2024-02-10 17:10    20  *
 427    2024-02-10 17:11    20  *
 428    2024-02-10 17:12    19  -
 429    2024-02-10 17:13    19  -
 430    2024-02-10 17:14    20  *
 431    2024-02-10 17:15    19  -
 ...    ..(  3 skipped).    ..  -
 435    2024-02-10 17:19    19  -
 436    2024-02-10 17:20    20  *
 437    2024-02-10 17:21    20  *
 438    2024-02-10 17:22    19  -
 439    2024-02-10 17:23    19  -
 440    2024-02-10 17:24    19  -
 441    2024-02-10 17:25    20  *
 442    2024-02-10 17:26    19  -
 443    2024-02-10 17:27    19  -
 444    2024-02-10 17:28    19  -
 445    2024-02-10 17:29    20  *
 446    2024-02-10 17:30    20  *
 447    2024-02-10 17:31    20  *
 448    2024-02-10 17:32    19  -
 449    2024-02-10 17:33    19  -
 450    2024-02-10 17:34    20  *
 451    2024-02-10 17:35    20  *
 452    2024-02-10 17:36    20  *
 453    2024-02-10 17:37    19  -
 456    2024-02-10 17:40    19  -
 457    2024-02-10 17:41    20  *
 458    2024-02-10 17:42    19  -
 461    2024-02-10 17:45    19  -
 462    2024-02-10 17:46    20  *
 463    2024-02-10 17:47    19  -
 ...    ..( 17 skipped).    ..  -
   3    2024-02-10 18:05    19  -
SCT Error Recovery Control:
           Read:     70 (7.0 seconds)
          Write:     70 (7.0 seconds)
Device Statistics (GP/SMART Log 0x04) not supported
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2           11  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2           11  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x000f  2            0  R_ERR response for host-to-device data FIS, CRC
0x0012  2            0  R_ERR response for host-to-device non-data FIS, CRC
0x8000  4      7183850  Vendor specific
