Tazman
- Mar 18, 2022
Hi everyone, I'm completely new to TrueNAS and really excited to get a home server.
But, the old computer I want to use for my server won't boot on the USB installer I made with RUFUS. Before you ask, Yes I set the BIOS to legacy mode and changed the priority of bootable devices. The USB stick I am using is working on a different Desktop, and my computer will boot on my Windows Installer USB stick. I even tried with Ubuntu and it booted normally.
I'm using an old, but functioning desktop I had laying around, the BIOS has a ton of settings, but it seems I haven't found the right one to modify in order to make this work... Here is the on the hardware, I'm copying what's on the BIOS System info page:
System Information
What I tried so far:
Default BIOS settings: unsurprisingly, didn't work
Unplug all the hard drives and try to boot on all USB Ports: No luck...
ATA/IDE Mode : Legacy /Native
S.M.A.R.T. : Disable /Enable
USB Legacy :Disable / Enable
USB Boot :Disable / Enable
Core Multiplexing Technology : Disable /Enable
XD Technology :Disable / Enable
I tried a combination of those settings but there are more...
Thank you for your help
System Information
Manufacturer: Procys
Product Name: DQ965GFEKR
Version: 602
Desktop Board InformationManufacturer: Intel Corp
Version: AAD41676-602
RAM2x: 2GB
Mushkin 991558
Hard drives (All desktop "grade") No judgment please, I'm doing this on a budget. Will upgrade in the future when needed.Booting USB stick: Nexxtech 32 GB
4TB WD Blue
WD40EZRZ - 19GXCBO
1TB Seagate
Barracuda 7200.12 ST31000524AS
160GB Seagate (to be used for install)(Currently has Windows installed on it)
Barracuda 7200.10, ST3160815AS
1TB Seagate
ST1000DM003
500GB Western Digital
WD5000AAJS - 22YFA0
Network CardWhatever is on the motherboard (not Wi-Fi), no extra Graphics or Network card.
It's not connected to the internet right now, but we're not there yet...
USB Legacy :
USB Boot :
XD Technology :
