leonardorame
- Jun 30, 2018
Hi, since yesterday a FreeNAS-11.3-U5 system cannot boot from its ssd boot disk anymore.
To try to fix it I installed the same version on an USB stick and booted from it.
Here's the output of zpool import:
As you can see there's a pool called Datos and freenas-boot, the former is composed of two 1.8tb spinning disks and the later is an ssd one.
I want to mount the freenas-boot to extract the configuration.
If I try to import it I get this error:
I guess that's because it tries to import
root@freenas:~ # zpool import
pool: Datos
state: ONLINE
status: The pool was last accessed by another system.
action: The pool can be imported using its name or numeric identifier and
the '-f' flag.
see: http://illumos.org/msg/ZFS-8000-EY
Datos ONLINE
mirror-0 ONLINE
gptid/b1e6b5b0-8bf3-11ea-96e6-04d9f5cef639 ONLINE
gptid/b1f22490-8bf3-11ea-96e6-04d9f5cef639 ONLINE
pool: freenas-boot
state: ONLINE
the '-f' flag.
freenas-boot ONLINE
ada0p2 ONLINE
root@freenas:~ # zpool status
pool: freenas-boot
state: ONLINE
scan: none requested
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
da0p2 ONLINE 0 0 0
errors: No known data errorsAs you can see there's a pool called Datos and freenas-boot, the former is composed of two 1.8tb spinning disks and the later is an ssd one.
"'/data/zfs' is not a valid directory"
freenas-boot over the already mounted USB, with the exact same pool name.
