james21984
- Aug 21, 2018
System:
Freenas 9.10
motherboard: ASRock E3C226D2I Mini ITX Server Motherboard LGA 1150 Intel C226
CPU: Intel Core i3-4170
Ram: 16GB non-ECC ram
Four 4TB hard drives in RaidZ2
One 4TB hard drive in USB enclosure
I had bought non-ECC ram by mistake originally then never got around to replacing it. From reading other posts it seems this may have contributed to the original problem. Raidz2 pool became unaccessible and freenas would not respond to anything. I reinstalled freenas on the flash drive and attempted to import the pool but the system would just reboot on normal import through the GUI. I was able to import it as read only through CLI but now I can not seem to figure out how to copy the data to the hard drive connected via USB. Below is the result of zpool import. Also I am posting zpool status after importing as read only. I am not that well versed in freenas but it seems the MediaDrive pool should be able to be imported normally but so far it seems to be a no go. I have 98% of the data from it backed up so it is not terrible if I cannot get anything copied but if I can get the other 2% of data copied off that would be great.
The only reference to copying data I can seem to find is with send and receive which seem to require snapshots however, when I try to do so I get a message saying a snapshot cannot be done when the pool is in read only. Any help on how to copy the data from the pool to the external hard drive would be appreciated.
[root@freenas] ~# zpool import
pool: JAILS
state: ONLINE
status: The pool was last accessed by another system.
action: The pool can be imported using its name or numeric identifier and
the '-f' flag.
see: http://illumos.org/msg/ZFS-8000-EY
JAILS ONLINE
gptid/644b0065-9294-11e8-81df-d05099c0bf1b ONLINE
pool: MediaDrive
state: ONLINE
the '-f' flag.
MediaDrive ONLINE
raidz2-0 ONLINE
gptid/b184ba9c-0ca4-11e6-a246-d05099c0bf1b ONLINE
gptid/b24dbf7c-0ca4-11e6-a246-d05099c0bf1b ONLINE
gptid/b304d197-0ca4-11e6-a246-d05099c0bf1b ONLINE
gptid/b434e670-0ca4-11e6-a246-d05099c0bf1b ONLINE
[root@freenas] ~# zpool status
pool: BackUp
state: ONLINE
scan: none requested
NAME STATE READ WRITE CKSUM
BackUp ONLINE 0 0 0
gptid/e1dd5e3f-a4bc-11e8-bc05-d05099c0bf1b ONLINE 0 0 0
errors: No known data errors
pool: MediaDrive
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: scrub in progress since Sun Aug 5 00:00:16 2018
4.26T scanned out of 4.26T at 1/s, (scan is slow, no estimated time)
192K repaired, 100.01% done
MediaDrive ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/b184ba9c-0ca4-11e6-a246-d05099c0bf1b ONLINE 0 0 0
gptid/b24dbf7c-0ca4-11e6-a246-d05099c0bf1b ONLINE 0 0 0
gptid/b304d197-0ca4-11e6-a246-d05099c0bf1b ONLINE 0 0 0
gptid/b434e670-0ca4-11e6-a246-d05099c0bf1b ONLINE 0 0 0
errors: 6 data errors, use '-v' for a list
pool: freenas-boot
state: ONLINE
freenas-boot ONLINE 0 0 0
da0p2 ONLINE 0 0 0
Freenas 9.10
pool: JAILS
state: ONLINE
the '-f' flag.
JAILS ONLINE
pool: MediaDrive
state: ONLINE
the '-f' flag.
MediaDrive ONLINE
raidz2-0 ONLINE
pool: BackUp
state: ONLINE
BackUp ONLINE 0 0 0
pool: MediaDrive
state: ONLINE
pool: freenas-boot
state: ONLINE
da0p2 ONLINE 0 0 0
