Noob question: iSCSI zvol to ESXi, should files be visible to FreeNAS?
nathanbuck
Hi everyone,
Long time lurker, first time poster.
TL;DR - should FreeNAS be able to see anything stored on a zvol, or even the zvol itself (outside of management/config)?
I've come across a potentially interesting scenario with my FreeNAS > ESXi iSCSI setup, and I'm curious if anyone can shed some light.
On Blaise I have 2 pools, each has a single zvol (about 80% size allocation), which is shared via iSCSI (point-to-point ethernet, static IP) to Albert.
- The smaller faster pool/zvol contains VM configs and boot vmdks
- The larger slower pool/zvol contains the 'Capacity' vmdks for a couple of VMs (Apple Photos libraries etc)
FreeNAS can see some of the folders, vmdks etc on the smaller pool, but can't see anything on the 'Capacity' pool.
Running
du -sh /* it shows a smaller usage than I expect too. My assumption is that FreeNAS wouldn't be able to see any files, as it's passing a block device straight to ESXi.
Really I'm just looking for a confirmation that the files I can see are heldover from the previous NFS setup (which at some point I rsync'd to the zvol), and not actually used by ESXi.
Thanks!
--- Background hardware info below here ---
** "Albert" ESXI 6.7u3 free licence **
Dell Poweredge T620- 2x Intel Xeon E5-2670, 64GB DDR3 ECC RAM
Pool1: LSI SAS2008 HBA to 10x Dell 4TB 7200rpm SAS disks
Onboard 2x Intel I350 GbE (link-aggregated to switch)
PCIe 2x Broadcom BCM5720 GbE (1 connected directly to Blaise/FreeNAS)
** "Blaise" FREENAS 11.3-RC1 **
Dell Poweredge R320- Intel Xeon E5-1410v2, 32GB DDR3 ECC RAM
Pool1: Dell H310 mini (flashed to SAS2008) to 4x Dell 600GB 15000rpm SAS disks
Pool2: LSI SAS2008 HBA to 8x Dell 2TB SAS disks
Onboard 2x Broadcom GbE (1 management LAN, 1 connected directly to Albert/ESXi)
nathanbuck
Below is the du outputs from each system. This seems to support the fact that it's looking at two completely different filesystems.
[nbadmin@albert:/vmfs/volumes/5de915de-0799d79c-3361-f01fafef4b22] du -sh *
128.0K ApplianceImages
31.3G ISOs
397.1G VirtualMachines
nbadmin@blaise[/mnt]# du -sh */*
1.7G SAS-15k-Z2-Pool/BlaiseTestVM(FreeNAS11.2)
3.6G SAS-15k-Z2-Pool/Carl(UnifiAppliance)
2.2G SAS-15k-Z2-Pool/Dmitry(DNS)
2.2G SAS-15k-Z2-Pool/Enrico(LetsEncryptACME)
32G SAS-15k-Z2-Pool/ISOs
18G SAS-15k-Z2-Pool/Klaus(Kali2019.3)
10G SAS-15k-Z2-Pool/Louis(Win10)
580M SAS-15k-Z2-Pool/Percy(pfSense)
A zvol is block storage, so nothing is "visible" to FreeNAS in that it won't mount a filesystem... you can dd the bits from the block storage, so in theory, you can see it if you're determined to do that, but it's not going to be easy.
nathanbuck
Awesome, thanks for the confirmation. :)
I'll blitz this so I don't get confused again.
This is the fun of test systems, I suppose!
