cyberdunks
- Mar 1, 2014
Here is my current configuration:
Stripe 1:
932GB WD
932GB Seagate
Stripe 2:
596GB WD
596GB WD
I realize I have no redundancy in the NAS with this configuration but it is not needed as I maintain an offsite cold-storage backup as well as a local hot backup.
I used the "Expand to Volume" option on the second stripe and added it to the first. My question is, if I add additional drives using the Expand to Volume option, will the data on the other 4 drives get wiped out?
Stripe 1:
932GB WD
932GB Seagate
Stripe 2:
596GB WD
596GB WD
