Hi, I am completely new to TrueNas and just build my first.
I installed 2 new WD red (4TB) drives to mirror. This is for home use. I am getting an error message about drive degradation.
2023-03-29 09:57:59 (America/New_York)"
I am not sure what to do. Do I just swap that drive with another one and it will rebuild the mirror automatically? Can I continue to use my nas for now? Can I remove the bad drive and run it with 1 drive or do I have to wait for the new drive to arrive and then install it? Is there a procedure for rebuilding the mirror? should I backup my mirror to another drive elsewhere just in case?
Thanks
Here is the result of
zpool status -v
zpool list -v
find /dev/ada* -exec smartctl -a {} \;
ast login: Fri Mar 10 11:17:55 on pts/1
FreeBSD 13.1-RELEASE-p7 n245418-79e75956dbb TRUENAS
TrueNAS (c) 2009-2023, iXsystems, Inc.
All rights reserved.
TrueNAS code is released under the modified BSD license with some
files copyrighted by (c) iXsystems, Inc.
For more information, documentation, help or support, go here:
http://truenas.com
Welcome to TrueNAS
Warning: the supported mechanisms for making configuration changes
are the TrueNAS WebUI and API exclusively. ALL OTHERS ARE
NOT SUPPORTED AND WILL RESULT IN UNDEFINED BEHAVIOR AND MAY
RESULT IN SYSTEM FAILURE.
root@truenas[~]#
root@truenas[~]# zpool status -v
pool: BigServer
state: DEGRADED
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A
scan: resilvered 49.5M in 00:00:04 with 0 errors on Fri Mar 24 15:58:20 2023
NAME STATE READ WRITE CKSUM
BigServer DEGRADED 0 0 0
mirror-0 DEGRADED 0 0 0
ada0p2 FAULTED 121 0 0 too many errors
gptid/57cccaf4-bf5c-11ed-a856-e0d55ea1ef75 ONLINE 0 0 0
BigServer/iocage/jails/Nextcloud/root:<0x0>
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:04 with 0 errors on Thu Mar 30 03:45:04 2023
boot-pool
state: ONLINE
root@truenas[~]# zpool list -v
NAME SIZE ALLOC FREE CKPOINT EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
BigServer 3.62T 368G 3.27T - - 0% 9% 1.00x DEGRADED /mnt
mirror-0 3.62T 368G 3.27T - - 0% 9.90% - DEGRADED
ada0p2 3.64T - - - - - - - FAULTED
root@truenas[~]# find /dev/ada* -exec smartctl -a {} \;
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p7 amd64] (local build)
Device Model: WDC WD40EFZX-68AWUN0
Serial Number: WD-WXV2AB21MK7A
LU WWN Device Id: 5 0014ee 2c03a580a
Firmware Version: 81.00B81
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Mar 30 13:21:02 2023 EDT
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 39) The self-test routine was interrupted
by the host with a hard or soft reset.
data collection: (41640) seconds.
capabilities: (0x11) SMART execute Offline immediate.
No Auto Offline data collection support.
command.
No Offline surface scan supported.
Self-test supported.
No Selective Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 443) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 226 226 021 Pre-fail Always - 3666
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 19
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 185
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 18
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 1
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 29
194 Temperature_Celsius 0x0022 120 114 000 Old_age Always - 30
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 188 145 000 Old_age Always - 3834
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Interrupted (host reset) 70% 173 -
# 2 Extended offline Completed without error 00% 101 -
# 3 Extended offline Interrupted (host reset) 90% 64 -
Selective Self-tests/Logging not supported
/dev/ada0p1: Unable to detect device type
Please specify device type with the -d option.
Use smartctl -h to get a usage summary
/dev/ada0p2: Unable to detect device type
Serial Number: WD-WXV2AB2AY86K
LU WWN Device Id: 5 0014ee 2c03a5630
was never started.
been run.
data collection: (44520) seconds.
command.
power-saving mode.
recommended polling time: ( 472) minutes.
3 Spin_Up_Time 0x0027 228 227 021 Pre-fail Always - 3600
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 17
194 Temperature_Celsius 0x0022 118 115 000 Old_age Always - 32
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
No Errors Logged
# 1 Extended offline Completed without error 00% 72 -
/dev/ada1p1: Unable to detect device type
/dev/ada1p2: Unable to detect device type
Device Model: SPCC Solid State Disk
Serial Number: GMAJ220434332
LU WWN Device Id: 5 000000 000005be7
Firmware Version: H220115
User Capacity: 256,060,514,304 bytes [256 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
TRIM Command: Available, deterministic, zeroed
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Mar 30 13:21:03 2023 EDT
was never started.
been run.
data collection: ( 33) seconds.
command.
power-saving mode.
Conveyance self-test routine
SCT capabilities: (0x0031) SCT Status supported.
SMART Attributes Data Structure revision number: 20
5 Reallocated_Sector_Ct 0x0013 100 100 050 Pre-fail Always - 0
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0012 100 100 000 Old_age Always - 60
167 Unknown_Attribute 0x0022 100 100 000 Old_age Always - 0
168 Unknown_Attribute 0x0012 100 100 000 Old_age Always - 0
169 Unknown_Attribute 0x0013 100 100 010 Pre-fail Always - 0
171 Unknown_Attribute 0x0032 000 000 000 Old_age Always - 0
172 Unknown_Attribute 0x0032 000 000 000 Old_age Always - 0
173 Unknown_Attribute 0x0012 200 200 000 Old_age Always - 4295032833
175 Program_Fail_Count_Chip 0x0022 100 100 010 Old_age Always - 0
180 Unused_Rsvd_Blk_Cnt_Tot 0x0033 100 100 000 Pre-fail Always - 25
187 Reported_Uncorrect 0x0032 100 000 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0012 100 100 000 Old_age Always - 32
194 Temperature_Celsius 0x0022 040 040 000 Old_age Always - 40 (Min/Max 40/40)
206 Unknown_SSD_Attribute 0x0032 200 200 000 Old_age Always - 1
207 Unknown_SSD_Attribute 0x0032 200 200 000 Old_age Always - 1
208 Unknown_SSD_Attribute 0x0032 200 200 000 Old_age Always - 1
209 Unknown_SSD_Attribute 0x0032 200 200 000 Old_age Always - 1
210 Unknown_Attribute 0x0032 200 200 000 Old_age Always - 32
211 Unknown_Attribute 0x0032 200 200 000 Old_age Always - 3
231 Unknown_SSD_Attribute 0x0023 100 100 005 Pre-fail Always - 0
233 Media_Wearout_Indicator 0x0032 100 100 000 Old_age Always - 0
234 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 6
241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 1
242 Total_LBAs_Read 0x0032 100 100 000 Old_age Always - 4
245 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
No Errors Logged
# 1 Extended offline Completed without error 00% 0 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
/dev/ada2p1: Unable to detect device type
/dev/ada2p2: Unable to detect device type
/dev/ada2p3: Unable to detect device type
Pool BigServer state is DEGRADED: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
The following devices are not healthy:
- Disk WDC WD40EFZX-68AWUN0 WD-WXV2AB21MK7A is FAULTED
2023-03-29 09:57:59 (America/New_York)"I am not sure what to do. Do I just swap that drive with another one and it will rebuild the mirror automatically? Can I continue to use my nas for now? Can I remove the bad drive and run it with 1 drive or do I have to wait for the new drive to arrive and then install it? Is there a procedure for rebuilding the mirror? should I backup my mirror to another drive elsewhere just in case?
Thanks
zpool status -v
zpool list -v
http://truenas.com
Welcome to TrueNAS
root@truenas[~]#
pool: BigServer
state: DEGRADED
pool: boot-pool
state: ONLINE
boot-pool
state: ONLINE
was never started.
command.
power-saving mode.
No Errors Logged
was never started.
been run.
command.
power-saving mode.
No Errors Logged
was never started.
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
