TM Rydland
- Nov 4, 2015
Hello, This fall I built my self a secondary FreeNAS server to keep my most important files safe in case of fire or burglary. The machine was to be placed at different house than my own which means that I will not have direct access to it once it is up and running. I have therefore spent a lot of time testing it so that i know that everything works, and for a couple of months it worked without any faults.
But the past month it has suddenly stopped responding and to get it going again I need to reset or cold start the computer.
I did get some out of swap space just before xmas when I changed the logging level to debug.
The only services that are currently running is SMART and SSH.
I have no jails or plugins going either.
Ive been using rsync over ssh to syncronise the vital data from my primary FreeNAS system.
The system specs:
8GB RAM
Intel Pentium G4400
MSI H110 Mainboard
three Seagate 2,5" 1TB drives set at RAIDZ1
I've been searching the forum for some solutions, but the closest thing to a solution was to increase the swap space, and that was apparently not recommended as it did not solve the problem but postponed it.
I have been thinking of resetting the system and wiping the harddrives to get a clean start again, but I am not sure if that will solve the problem.
The system specs:
8GB RAM
Intel Pentium G4400
MSI H110 Mainboard
