Victor-Zorro
- Oct 30, 2020
Hi There,
I am testing truenas scale as a vm. I am planning to replace my existing Cent OS wit truenas scale.
Since I can delete a layer of os in my setup. I will run several vm's. I use Node-Red, to integrate into my home automation.
I am really happy so far with what I've seen of scale! Like the pass-through option of devices to vm's
Node red will start my workstation vm with the command "virsh start windows10"
and some ubuntu test vm's etc...
So far, I managed to install nodeJS:
sudo apt update
sudo apt install nodejs npm
and then node-red with:
npm install -g --unsafe-perm node-red
Witch is convenient! Because Now I can start stop vm's through my touch screen workspace control.
The control can also shutdown my server with ipmi tool. To save energy when I am not working.
Questions: will those packages be deleted after each update? and to what folder are packages installed? default debian is usr/bin but not here..
And. I noticed ha apt upgrade does work to, would this be harmful? Or will this be the way to also update Truenas?
sudo apt update
