Node Red In A Jail
Soloam
I'm trying to install node red in a jail, but it keep getting this error:
root@nodered:/ # npm install -g --unsafe-perm node-red
npm ERR! code Z_DATA_ERROR
npm ERR! errno Z_DATA_ERROR
npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/node-red: invalid distance too far back
npm ERR! A complete log of this run can be found in:
npm ERR!	 /root/.npm/_logs/2018-05-22T21_32_38_094Z-debug.log
root@nodered:/ # tail /root/.npm/_logs/2018-05-22T21_32_38_094Z-debug.log
11 verbose stack	 at Gunzip.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/mississippi/node_modules/pump/index.js:31:21)
12 verbose cwd /
13 verbose FreeBSD 11.1-STABLE
14 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "-g" "--unsafe-perm" "node-red"
15 verbose node v10.1.0
16 verbose npm  v6.0.1
17 error code Z_DATA_ERROR
18 error errno Z_DATA_ERROR
19 error Invalid response body while trying to fetch https://registry.npmjs.org/node-red: invalid distance too far back
20 verbose exit [ 1, true ]
root@nodered:/ # node -v
v10.1.0
root@nodered:/ # npm -v
6.0.1
Any idea?
Thank you
DrKK
FreeNAS Generalissimo
Just for S&G, I wonder if it works fine with Node v8.
Can you try perhaps v8 instead of v10 node?
Soloam
A lot of warnings in the install to upgrade for safty reasons, but it works, its running:
pkg install node8
pkg install npm-node8
npm WARN deprecated bcrypt@1.0.3: bcrypt < v2.0.0 is susceptible to bcrypt wrap-around bug. Upgrade to bcrypt >= v2.0.0 for improved support for newer bcrypt hashes
npm WARN deprecated i18next-client@1.10.3: you can use npm install i18next from version 2.0.0
npm WARN deprecated nodemailer@1.11.0: All versions below 4.0.1 of Nodemailer are deprecated. See https://nodemailer.com/status/
npm WARN deprecated mailparser@0.6.2: This project is unmaintained
npm WARN deprecated mimelib@0.3.1: This project is unmaintained
npm WARN deprecated mailcomposer@2.1.0: This project is unmaintained
npm WARN deprecated buildmail@2.0.0: This project is unmaintained
/usr/local/bin/node-red -> /usr/local/lib/node_modules/node-red/red.js
/usr/local/bin/node-red-pi -> /usr/local/lib/node_modules/node-red/bin/node-red-pi
> bcrypt@1.0.3 install /usr/local/lib/node_modules/node-red/node_modules/bcrypt
> node-pre-gyp install --fallback-to-build
node-pre-gyp ERR! Tried to download(404): https://github.com/kelektiv/node.bcrypt.js/releases/download/v1.0.3/bcrypt_lib-v1.0.3-node-v57-freebsd-x64.tar.gz
node-pre-gyp ERR! Pre-built binaries not found for bcrypt@1.0.3 and node@8.11.1 (node-v57 ABI) (falling back to source compile with node-gyp)
gmake: Entering directory '/usr/local/lib/node_modules/node-red/node_modules/bcrypt/build'
 CXX(target) Release/obj.target/bcrypt_lib/src/blowfish.o
 CXX(target) Release/obj.target/bcrypt_lib/src/bcrypt.o
 CXX(target) Release/obj.target/bcrypt_lib/src/bcrypt_node.o
 SOLINK_MODULE(target) Release/obj.target/bcrypt_lib.node
 COPY Release/bcrypt_lib.node
 COPY /usr/local/lib/node_modules/node-red/node_modules/bcrypt/lib/binding/bcrypt_lib.node
 TOUCH Release/obj.target/action_after_build.stamp
gmake: Leaving directory '/usr/local/lib/node_modules/node-red/node_modules/bcrypt/build'
+ node-red@0.18.6
added 335 packages from 353 contributors in 597.925s
So the last version does not work in FreeBSD?
thank you
DrKK
So, I don't know much about node.js at all. However, I did some reading about it when I saw your post, and everything I've found on node-red referred to version 6 or 8 LTS for the underlying node. Literally everything.
I therefore suspected that it was node-red itself that may be expecting version 8.
I don't have a better explanation than that, unfortunately---you should do some research with the node-red guys; I would doubt it's FreeBSD's fault. I am glad, though, that my suggestion at least gets you going with a working install.
Soloam
Thank you for all your help @DrKK
DrKK
