No network in jail after upgrade to FreeNAS 11
fillg1
Hi folks
I just upgraded to from 9.10 to FreeNAS 11 and noticed that my old portjail has no working network anymore.
ifconfig shows
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:4b:da:00:09:0b
inet6 fe80::4b:daff:fe00:90b%epair0b prefixlen 64 scopeid 0x2
inet6 2a02:908:1d0:ab00:4b:daff:fe00:90b prefixlen 64 autoconf
nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL>
status: active
A new created jail seems to work (all defaults and DHCP)
groups: lo
epair1b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 92:94:80:0d:00:6d
inet 192.168.42.41 netmask 0xffffff00 broadcast 192.168.42.255
inet6 2a02:908:e348:7d00::1 prefixlen 64 tentative
status: active
groups: epair
Any hints?
D
dlavigne
Guest
Do you get any errors if you dhclient epair0b? (Note that you may have to killall dhclient first).
fillg1
strange
root@port:/ # dhclient epair0b
ifconfig: ioctl (SIOCAIFADDR): Invalid argument
epair0b: not found
exiting.
SweetAndLow
Sweet'NASty
strange
epair0b: not found
exiting.
This could be a major abi change going from freebsd 10 to 11. We should test this to know for sure but you should consider rebuilding your jails. New jails is a better solution.
gleggate
Stumbled across this issue as I'm having the same issue with 3 out of 4 jails. I tried switching the interface from static IP to DHCP but I'm getting the same result as fillg1.
Erich
I can report exactly the same behaviour (3 out of 6 jails), FreeNAS box went from 10.3 to 11.0-U2.
Also tried DHCP manually and via jail restart but no success.
The jails which stay offline are the same ones each time. They are of mixed types, portjails and Standard, which doesn't matter in their ability to get network.
albrandwood
I don't know if this will help ... but it worked for me ...
SSH to freenas (or use the java terminal) and sudo to root. Navigate to the Jails dataset (in my case /mnt/Data/Jails). There you will find the .<jailname>.meta folder ... in there is a file called "vnet". Removing this file, appears to have resolved my jail network issues. then just restart the jail. It should start working again. (And no, I don't know what the vnet file does, as my jails were created 3 years ago!)
freenas$ sudo su -
Password:
ssh user@freenas
user@freenas's password:
Welcome to FreeNAS
freenas$ cd /mnt/Data/Jails/
freenas$ ls -al
total 15
drwxr-xr-x  16 root  wheel  17 Aug 30 22:33 .
drwxr-xr-x  16 root  wheel  17 Aug 30 20:45 ..
drwxr-xr-x   2 root  wheel  18 Aug 30 20:46 .DB.meta
drwxr-xr-x  19 root  wheel  21 Jun 15  2014 DB
freenas$ sudo su rm -f /mnt/Data/Jails/.DB.meta/vnet
Password:
If not, the quick hack solution ... This will get your jail back online, albeit not on startup.
IFACE=`ifconfig | egrep ^epair[0-9]b | cut -d: -f1`
ifconfig $IFACE 192.168.xxx.yyy
route add default 192.168.xxx.1 -interface $IFACE
IceBoosteR
SweetAndLow
Sweet'NASty
freenas$ sudo su -
Password:
ssh user@freenas
Welcome to FreeNAS
freenas$ ls -al
total 15
Password:
Do not just delete files that you don't understand. Someone way smarter than you decided it needed it be there.
If you want to disable vimage you turn that off in the gui, you can do the same for vnat.
bed
I think I may be victim to the same issue. I am getting ready to buy new hardware and do a fresh build as its been ages since I upgraded my freenas.
So far I have built a development freenas in a vmware VM with a fresh install of of freenas 11U4 and created 2 jails. Both have static IP's. The jails can ping each other but only one of them can ping the host and neither of them can ping the gateway.
After 2 days of researching I finally ended up here. I hope someone can help shed some light on this for me.
Thanks/
IceBoosteR
Thanks/
Please open a bug ticket, set the target version to 11.1 and with high prio, as this is essential for freenas and should work. Hopefully this can get figured out and get fixed.
bed
Just thought I would post an update regarding the bug I submitted.
If you are running in a virtual environment, enabling promiscuous mode on your virtual network will allow your jail networks to function properly. At least in my case.
I don't know if this is considered a permanent fix especially regarding any security issues this might present to some users. Since I am only using the virtual environment for testing before deploying on bare metal this is much less of a concern to me.
xxsj
Had same problem as OP and tried the steps provided originally, and got the same error:
This is breaking 7 out of 9 of my jails currently. (The oldest 7... hmm)
Static IP doesn't help, started after upgrading from 9.1x train to 11.1 train.
VIMAGE cannot be unchecked, it simply wont let me in advanced mode even though I can see the checkbox and uncheck the box above it (autostart)
xxsj
I was able to get static networking working in my jails, when I cleared every field under advanced mode excluding the mac address, the textbox at the bottom, the ipv4 address and netmask, unchecked vimage, and rebooted the jail. Hope this helps someone else!
vzmr82
Just upgraded from 9.3.1 to 11.1-U2 and had this same problem. Unchecking vimage solved the problem. Thanks.
UPDATE===
No, it did not. Even thought I have a static IP address, my Plex Media Server just stopped working. As per this post https://forums.plex.tv/discussion/2...ng-posters-with-vimage-not-enabled-on-freenas, I have other network problems.
So I still need to solve the problem by not unchecking VIMAGE...
jg3
tough to believe this is still open.
I updated from 11.1-U4 (which was working fine, oddly enough) to -U7 and now none of my jails seem to have any kind of network access. Poked around a bunch with the notes in this thread, finally decided to destroy and re-create the jail.
Created a new jail via CLI:
root@fn:~ # iocage create -n "plex" -p /tmp/pkg.json -r 11.1-RELEASE vnet="on" allow_raw_sockets="1" bpf=yes dhcp=on boot="on"
plex successfully created!
Testing SRV response to FreeBSD
Error: error sending query: General LDNS error
{repo} could not be reached, please check your DNS
Creating it from the WebUI also fails because this bug still exists where ticking the box for BPF when creating a jail causes creation to fail:
*** true is not a valid value for bpf. Value must be no or yes ***
Such a bummer. I again created a jail via CLI and the WebUI with a static IP and it still doesn't get network.
So here I am ... unable to ping my gateway or the freenas host, and no idea what to do to make it work. Help?!
root@plex:~ # ifconfig
        groups: lo
        options=8<VLAN_MTU>
        ether 02:ff:60:14:fa:0a
        hwaddr 02:2d:a0:00:0a:0b
        inet 10.39.6.88 netmask 0xffffff00 broadcast 10.39.6.255
        status: active
        groups: epair
root@plex:~ # netstat -rnf inet
netstat: kvm not available: /dev/mem: No such file or directory
Routing tables
Internet:
Destination        Gateway            Flags     Netif Expire
default            10.39.6.254        UGS     epair0b
10.39.6.0/24       link#2             U       epair0b
10.39.6.88         link#2             UHS         lo0
127.0.0.1          link#1             UH          lo0
root@plex:~ # ping 10.39.6.254
PING 10.39.6.254 (10.39.6.254): 56 data bytes
ping: sendto: Host is down
^C
--- 10.39.6.254 ping statistics ---
9 packets transmitted, 0 packets received, 100.0% packet loss
root@plex:~ # ping 10.39.6.99
PING 10.39.6.99 (10.39.6.99): 56 data bytes
^C
--- 10.39.6.99 ping statistics ---
7 packets transmitted, 0 packets received, 100.0% packet loss
jg3
Nope! I threw in the towel. I blew away all the jails, created a VM and an 11.2-U2.1 FreeNAS system on another machine, verified that creating jails worked there, rsync'd the data ... then upgraded the original system. So far that's worked.
With the stuff I read about the upgrade to 11.2 I wanted to wait, but from what I've seen so far, the 11.2-U2.1 jail admin stuff works a treat.
