FreeNAS 11, Jails, no IPv6
technopop
I'm not sure what I'm doing wrong here....
The host gets an autoconf address fine. I'm able to get to the GUI via the IP6 address.
The jails don't get an autoconf address from the dhcp6 server.
If I set it manually in the jail settings, ifconfig shows the address but trying to ping my router, I get
# ping6 2607:f2c0:f00f:e600::1
ping6: UDP connect: Can't assign requested address
ifconfig on the statically assigned jail... I don't see that fe80:::: /56 address like I see in the host and the autoconf jails.
# ifconfig
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
groups: lo
epair6b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 82:9f:a3:79:60:ad
inet 192.168.73.18 netmask 0xffffff00 broadcast 192.168.73.255
inet6 2607:f2c0:f00f:e600:1::2 prefixlen 56 tentative
status: active
groups: epair
ifconfig epair6a and ethernet em1 on the host
root@storage:~ # ifconfig epair6a
epair6a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:ff:e0:00:0b:0a
nd6 options=1<PERFORMNUD>
status: active
groups: epair
root@storage:~ # ifconfig em1
em1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=42098<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,VLAN_HWTSO>
ether 00:25:90:db:42:b2
inet 192.168.73.15 netmask 0xffffff00 broadcast 192.168.73.255
inet6 fe80::225:90ff:fedb:42b2%em1 prefixlen 64 scopeid 0x2
inet6 2607:f2c0:f00f:e600:2::1241 prefixlen 56
nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL>
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
technopop
I enabled the epair#b interface and it works.
ifconfig epair#b inet6 2607:####:####::#### prefixlen 56
However, if I modify rc.conf and put a line
ifconfig_epair#b_ipv6="inet6 ####:####::#### prefixlen 56"
and restart, that line gets removed and I'm back to setting it by hand again.
What's the proper way to do this or how can I get around freenas rewriting the jail's rc.conf file?
D
dlavigne
Guest
Please create a bug report at bugs.freenas.org and post the issue number here.
blubberor
for me
ifconfig epair#b inet6 2607:####:####::#### prefixlen 56 --> I addapted it accrodingly (full IP and prefixlen 64)
did not work as a workaround
	   groups: lo
epair1b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
	   options=8<VLAN_MTU>
	   ether 16:87:aa:3c:14:c2
	   inet 192.168.**.** netmask 0xffffff00 broadcast 192.168.**.**
	   inet6 fe80::****:****:****:14c2%epair1b prefixlen 64 scopeid 0x2
	   inet6 fd00::****:****:****:14c2 prefixlen 64 autoconf
	   inet6 ****:908:***:****:****:****:****:14c2 prefixlen 64
	   status: active
	   groups: epair
is there any temporary workaround that would make it work.
Would love to get access to the jails. Access to freenas works very nice.
thanks,
blubberor
blubberor
thanks. saw this already and thought there might be a manual workaround.
for whatever reason after some time 2 of my jails (nextcloud and plexmediaserve) get a IPv6 and at least yesterday for some hours I could access nextcloud - stopped working though. Keeps having the right config and keeps having the external IPv6...
emby does not get any IPv6 e.g.
