configuring jails for IPv6
blubberor
Hello everybody.
there are and there will be more and more people having prpoblems with this.
I am unable configure freenas 11.2 beta for assigning real IPv6 for the jails.
Under network I created an interface re0 w ith the name IPv6 and autoconfigure for IPv4 (DHCP) and IPv6
now I am stuck though with configuring the jails.
These are my iocage and ifconfig outputs:
[root@freenas ~]# iocage list
| JID |   NAME	| STATE |   RELEASE	| IP4  |
| 5   | emby	  | up	| 11.1-RELEASE | DHCP |
| 1   | nextcloud | up	| 11.1-RELEASE | DHCP |
| -   | plex	  | down  | 11.1-RELEASE | DHCP |
[root@freenas ~]# ifconfig
re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=82099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
		ether d0:50:99:76:a2:a8
		hwaddr d0:50:99:76:a2:a8
		inet6 fc12::a110:92ff:fe12:b1h8%re0 prefixlen 64 scopeid 0x1
		inet6 3e12:132:542:f7a0:a110:92ff:fe12:b1h8 prefixlen 64 autoconf
		inet6 fc12::a110:92ff:fe12:b1h8 prefixlen 64 autoconf
		inet 192.168.178.21 netmask 0xffffff00 broadcast 192.168.178.255
		nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL>
		media: Ethernet autoselect (1000baseT <full-duplex,master>)
		status: active
		options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
		inet6 ::1 prefixlen 128
		inet6 fc12::1%lo0 prefixlen 64 scopeid 0x2
		groups: lo
		ether 02:af:67:da:6e:00
		nd6 options=1<PERFORMNUD>
		groups: bridge
		member: vnet0:5 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 5 priority 128 path cost 2000
		member: vnet0:1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 4 priority 128 path cost 2000
		member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 1 priority 128 path cost 20000
vnet0:1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		description: associated with jail: nextcloud
		options=8<VLAN_MTU>
		ether 02:ff:60:ba:b5:81
		hwaddr 02:28:10:00:04:0a
		status: active
		groups: epair
vnet0:5: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		description: associated with jail: emby
		options=8<VLAN_MTU>
		ether 02:ff:60:79:aa:5f
		hwaddr 02:28:10:00:05:0a
		status: active
		groups: epair
[root@freenas ~]# ifconfig -a
		status: active
		groups: lo
		groups: bridge
I am getting confused now where to enter the correct settings for net iocage network and where or what I have to clone.
I am use more and more people will come up with these problems so having a detailed thread that helps would be highly appreciated.
I changed all IPs in the thread so that no information gets lost. so no worries.
Thanks so much.
B
passuff
Hello everybody.
		status: active
		groups: lo
		groups: bridge
		options=8<VLAN_MTU>
		status: active
		groups: epair
		options=8<VLAN_MTU>
		status: active
		groups: epair
		status: active
		groups: lo
		groups: bridge
Thanks so much.
B
I have the same issue. No autoconfig option is available for IPv6, just for IPv4... Why?
