Nginx Settings
Biscra
Hello!
I'm looking to find out where to locate the nginx configuration files on TrueNAS Scale when installed using custom applications. For example, I'd like to remove the nginx version when encountering an error page by using "server_tokens off;". Essentially, I'm trying to find where the nginx configuration files are located. Thanks in advance!
